#1 2025-01-04 16:39
chickenlittle2
The attempt to mount a file system with type vfat at /boot/efi failed
Hello,
I have an old netbook on which I had Q4OS 2.7 installed along with an old version of Android (dual boot). As I decided to remove the Android OS, I wanted to do a fresh install of the newest version of Q4OS (5.7). I downloaded the new version, created a bootable USB using rufus and started the installation.
Right now, I am stuck at the "Partition disks" step due to the "The attempt to mount a file system with type vfat in SCSI1 (0, 0, 0), partition #4 (sda) at /boot/efi failed" message after trying to "finish partitioning and write changes to disk". I erased the data on partitions #1 and #3 prior to trying to "finish partitioning and write changes to disk". I have one HDD (320GB) which is partitioned in the following way (partition disk step display below):
                                              Partition disks
Guided partitioning
Configure software RAID
Configure the Logical Volume Manager
Configure encrypted volumes
Configure iSCSI volumes
SCSI1 (0, 0, 0) (sda) - 320.1 GB ATA Hitachi
#1     primary     107.4 GB             K     ext4
#2     primary     16.1 GB               F     swap       swap
#3     primary     196.6 GB             F     ext4         /
#4     primary     16.8 MB       B      K     ESP
SCIS5 (0, 0, 0) (sdb) - 8.0 GB SanDisk Cruzer
#1    primary      8.0 GB         B             fat32
#2    primary      32.3 kB
Undo changes to partitions
Finish partitioning and write changes to disk
Notes:
- Android was installed on partition #1 (sda).
- Q4OS 2.7 was installed on partition #3 (sda). It replaced the original Windows 7 starter OS.
- When I got to this step I erased the data on partitions #1 and #3. There are no more OS installed on the computer.
- sdb is the bootable USB.
I did some research and based on the message, there are various causes of this. The issue seems to be with EFI (partition #4). I am average in terms of computer literacy and the only thing I know about EFI is that it has something to do with the BIOS (if I am not mistaken). Normally, I would try to play with different settings and options but I read somewhere that if I mess up the EFI partition settings it's possible that BIOS can get "damaged" and unusable (that's how I understand it).
Could it be that I am stuck at this step because of the way the partitions are setup right now due to previous systems installation? How can I get past this message to continue Q4OS installation?
I would appreciate any help as right now I have no OS installed on this device.
Below are more options and partitions settings in the "Partition disk" step:
                                                   Guided partitioning
Partitioning method:
Guided - use entire disk
Guided - use entire disk and set up LVM
Guided - use entire disk and set up encrypted LVM
                            Partition #1 of SCSI1 (0, 0 , 0) (sda) - settings
Use as:                           ext4 journaling file system
Format the partition:        no, keep existing data
Mount point:                   none
Mount options:                defaults
Bootable flag:                 off
Resize the partition (currently 107.4 GB)
Erase data on this partition
Delete this partition
Done setting up the partition
                            Partition #2 of SCSI1 (0, 0 , 0) (sda) - settings
Use as:                           swap area
Bootable flag:                 off
Resize the partition (currently 16.1 GB)
                            Partition #3 of SCSI1 (0, 0 , 0) (sda) - settings
Format the partition:        yes, format it
Mount point:                   /
Bootable flag:                 off
Resize the partition (currently 196.6 GB)
                            Partition #4 of SCSI1 (0, 0 , 0) (sda) - settings
Use as:                           EFI System Partition
Bootable flag:                 on
#2 2025-01-04 18:20
Re: The attempt to mount a file system with type vfat at /boot/efi failed
If you want to have only the latest version of Q4OS, I think it would be easier to let the installer use the whole disk to install Q4OS 5. Did you at least see that option?
#3 2025-01-04 19:19
chickenlittle2
I believe so.
When I start the computer, I get a black screen with the following messages:
Failed  to open \EFI\BOOT - Not Found
Welcome to GRUB!
Then, the installer boots and I get the following options:
Q4OS Classic Install
Q4OS No questions, FULL automated
Advanced options...
If I select the first option, I go through the installation steps and get to the "Partition disks" step. That's where I can use "Guided partitioning -> Guided - use entire disk".
#4 2025-01-04 21:50
chickenlittle2
Selecting the installation using the entire disk allowed me to get past the "Partition disk" step. However, the installation never completed as the computer froze. I tried the installation process several times and the computer kept randomly freezing at different steps, sometimes right after starting the installation and sometimes just before the completion.
Then, I tried installing Q4OS 4.13. I did not get the message "Failed  to open \EFI\BOOT - Not Found", only "Welcome to GRUB!". The installation process also did not complete as the computer froze.
Then, I tried installing Q4OS 2.7 (the one I previously had installed) and everything went well until the end during the "Install the GRUB boot loader on a hard disk" step. That's when I got this message:
Unable to install GRUB in /dev/sda
Executing 'grub-install /dev/sda' failed.
This is a fatal error.
#5 2025-01-05 16:31
chickenlittle2
To rule out the computer, I tried installing another Linux distribution and it worked. I prefer Q4OS but it will have to do until I figure out how to overcome Q4OS installation issues.
Not sure why the computer is freezing while trying to install later versions (4.13 and 5.7) of Q4OS and why I can't reinstall the old version (2.7) which worked perfectly.
#6 2025-01-05 18:09
Perhaps you could first delete one by one all 4 partitions, then try to install again.
#7 2025-01-08 02:10
chickenlittle2
I had erased data on those partitions but did not delete the partitions. Now, all of the partitions were combined into one when I installed the other Linux distribution.
I think the Q4OS installation issue could be related to BIOS Legacy vs UEFI. I have BIOS Legacy and Q4OS requires UEFI. But I don't understand how I was able to install Q4OS 2.7 before and can't now.
#8 2025-01-08 03:51
Q4OS doesnt require UEFI but can run with UEFI. I have many systems not using UEFI that are running Q4OS both Trinity and KDE. You may be having some drive issues such as file corruption that caused some issues. Doing a fresh install on a clean drive might clear things up.
#9 2025-01-08 06:36
I think the problem is that you have EFI things on your drive (how they appeared on a BIOS Legacy system is a mystery to me). Deleting all the 4 partitions might solve the issue.
And you'll get back a full 320 GB available for your new OS (otherwise it would be installed on one of the 107.4 GB or 196.6 GB partition, the other one being wasted disk space).
#10 2025-01-08 10:40
We would recommend you to delete all the existing partitions on the disk, as said by @hchiper.
Afterwards run Q4OS installer, it supports both UEFI as well as legacy BIOS, exactly the same way as plain Debain.
#11 2025-01-08 22:29
chickenlittle2
I reinstalled from zero on the entire disk (one partition). It worked this time. The computer did not freeze. Everything is working properly.
Thank you hchiper, crosscourt and q4osteam! I appreciate your help!!!
#12 2025-01-08 23:26
Glad you got it working!  smile
