#1 2025-01-03 12:28
Install Software Centre's softwares using the CLI?
Is there any advantage to install software from the Software Centre rather than from repositories (sudo apt install ...), and in this case is there a way to install / uninstall a Software Centre's software using the command line? I'm talking of Firefox, Thunderbird, LibreOffice, The GIMP, gparted, Update Manager, and others.
I ask the question because I'm writing a python3 script to reconfigure a system after a reinstall. This script will also reinstall a lot of packages and selectively restore dot-files and -directories saved during reinstall to
$HOME/dotfiles_backup_yyyy_mm_dd_HH_MM_SS/
(in the case users directories reside on a separate partition).
I'd like this script to be compatible with current and future versions of Q4OS.
#2 2025-01-03 12:43
Re: Install Software Centre's softwares using the CLI?
Yes.
- Installers may take care about some Q4OS specific dependencies.
- There are some software in the Software Centre, that isn't present in the default Debian repositories, for example Firefox, Google Chrome and others.
- Installers also provide automatic installation of language packages, for example for Libreoffice, Firefox and others.
- Software center offers Flatpak packages too.
hchiper wrote:
... is there a way to install a Software Centre's software using the command line?
Yes. First you need to download installer, see an example for Firefox:
$ sh /usr/share/apps/q4os_system/bin/dwnld_instl.sh q4os-firefox
run non interactive installer in commandline mode:
$ sudo qsinst /tmp/.dwnlinstl/setup_q4os-firefox_4.4-a1_all.qsi
or run installer in gui mode:
$ appsetup2.exu /tmp/.dwnlinstl/setup_q4os-firefox_4.4-a1_all.qsi
hchiper wrote:
I ask the question because I'm writing a python3 script to reconfigure a system after a reinstall ...
Maybe custom profiles would be suitable ? https://www.q4os.org/dqa016.html
#3 2025-01-04 23:31
Many thanks for your response.
It was easy to guess the names such as q4os-firefox, q4os-thunderbird, q4os-libreoffice, q4os-vlc, q4os-gparted, q4os-updater,...
Unfortunately other guesses don't work: q4os-gimp, q4os-okular, q4os-timeshift, q4os-keepassxc,...
Is there a place where I can find the appropriate names?
#4 2025-01-05 12:07
Software center gets installers names from "/usr/share/apps/q4os_system/q4os_swcentre/*.qctcrc", however some of installers comes directly from Debian repositories, see "/usr/share/apps/q4os_system/q4os_swcentre/appsdeb/50_swcapp.lst" file.
