#1 2024-12-09 16:06
Let's darken themes
Darkonair visual theme for Trinity desktop is updated, and now considered stable. It's available directly from the Lookswitcher application.
Get Darkonair theme for Plasma:
$ sudo apt install q4os-darkonair-plasma-theme
Enjoy the themes smile
#2 2024-12-09 17:07
Re: Let's darken themes
Great. cool
#3 2024-12-09 19:19
Nice!
#4 2024-12-10 15:58
q4os_forever
I like it!!!
#5 2024-12-12 22:19
badmotorscooter
Dark theme very nice!  Looks slick with the oxygen icons.
#6 2025-01-19 07:31
max1million
I prefer a lighter dark or darker light with a dingy white for window contents. Like I've had for the past 24? years. Maybe i should call it a warmer mid tone color. R214,G189,B152 for window button, taskbar, menu, yadayda, with some variation of that or a warmer gray for highlights,the dingy white contents and lower level backlight/brightness. Altough I did transparentize the taskbar, that's new  for me.Haven't found any like it, stopped looking..
#7 2025-01-19 07:48
max1million
oh well at 297.5KB the screen shot is too big, and i have nothing handy to reduce it to unknown size at the moment so no visual and no ability to color picker copy.
also note put a comma between window, button above post.
#8 2025-01-19 19:31
I use KDE primarily but I also run TDE. I prefer KDE because of the customization features and wider range of choices overall for look/appearance.
#9 2025-01-22 23:22
Excuse me, is it available for Gemini / TDE 14.0.12 too? A theme "Darkonair" isn't offered here in the Lookswitcher.
#10 2025-01-23 00:41
I dont believe its available for TDE, only Plasma.
#11 2025-01-23 09:34
FlexQ4 wrote:
... is it available for Gemini / TDE 14.0.12 too? A theme "Darkonair" isn't offered here in the Lookswitcher.
Yes, Darkonaire for Trinity is available in Gemini. You only need to update Apt:
$ sudo apt update
and install Lookswitcher from software center. Darkonair will be listed in Lookswitcher, so you can switch easily.
#12 2025-01-23 17:10
$ sudo apt update
Yes, thank you! The theme is nice, i'd like to use it, but the looks of Wine_Classic is more important for me (but i doubt there will come a darkend theme for it, unfortunately).
#13 2025-02-04 18:12
VegaLinuxQ4
Will be possible to use "BREEZE DARK" theme in TDE?
#14 2025-02-18 23:32
supra2jz
Is there some other dark themes for the Trinity DE?
Q4OS running on IBM ThinkPad T60 - C2D T7200, 3GB RAM, 128GB SSD / pockethacks.com / jdmedmparts.com
#15 2025-02-19 03:42
VegaLinuxQ4
We'll wait dev's respons, since TDE's not noob friendly as other DEs in theming.
We have that "look switcher" but only 1 theme to choose, it's limited.
#16 2025-02-19 04:06
Take a look at this really old thread that will give you an idea of whats possible, but TDE has changed a lot since this thread was originally posted.  Post #5 is worth looking thru.
www.q4os.org/forum/viewtopic.php?id=693
