#1 2024-08-15 11:25
Raintania
Cannot use Internet
Currently typing this in from a Live CD of Antix.
Dmesg showed me this warning:
'kde  connected' uses wireless extensions which will stop working with Wi-Fi 7 hardware; use nl80211
Cannot really change or update Network Manager, because there is no internet even though I am connected.
freaky
#2 2024-08-16 06:31
Re: Cannot use Internet
That is a warning message, not an error. Wi-Fi connection should work. What is the output of this command?
$ ip address
nl80211 is likely a driver for Wi-Fi cards. Which one do you have? And what is your hardware setup and your software configuration?. Please give at the output of
$ inxi -Fxxx
After that, if you are "connected" (what do you mean precisely?) and have no Internet, the problem might be with your access point or your Internet provider. What is the output of
$ ping -c4 q4os.org
#3 2024-08-16 11:44
Raintania
$ ip address
$ inxi -Fxxx
$ ping -c4 q4os.org
Hi, I mean I appear to be connected but I am not. I cannot access the internet. No problems on any other devices and I'm thinking this has something to do with the tde-networkmanager.
The outputs for the stuff you wanted are here, in the meantime I have to install Devuan.
Dmesg output regarding network
[   60.928668] warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[  202.655101] wlp3s0: authenticate with 60:32:b1:95:2e:7e (local address=80:c5:f2:bf:38:97)
[  202.765566] wlp3s0: send auth to 60:32:b1:95:2e:7e (try 1/3)
[  202.765902] wlp3s0: aborting authentication with 60:32:b1:95:2e:7e by local choice (Reason: 3=DEAUTH_LEAVING)
[  202.991150] wlp3s0: authenticate with 60:32:b1:95:2e:7e (local address=80:c5:f2:bf:38:97)
[  203.101137] wlp3s0: send auth to 60:32:b1:95:2e:7e (try 1/3)
[  203.209688] wlp3s0: send auth to 60:32:b1:95:2e:7e (try 2/3)
[  203.211308] wlp3s0: authenticated
[  203.213613] wlp3s0: associate with 60:32:b1:95:2e:7e (try 1/3)
[  203.225646] wlp3s0: RX AssocResp from 60:32:b1:95:2e:7e (capab=0x1411 status=0 aid=4)
[  203.226090] wlp3s0: associated
[  203.314691] wlp3s0: Limiting TX power to 27 (27 - 0) dBm as advertised by 60:32:b1:95:2e:7e
[  453.716197] wlp3s0: deauthenticating from 60:32:b1:95:2e:7e by local choice (Reason: 3=DEAUTH_LEAVING)
[  457.486989] wlp3s0: authenticate with 60:32:b1:95:2e:7e (local address=80:c5:f2:bf:38:97)
[  457.597951] wlp3s0: send auth to 60:32:b1:95:2e:7e (try 1/3)
[  457.599712] wlp3s0: authenticated
[  457.606122] wlp3s0: associate with 60:32:b1:95:2e:7e (try 1/3)
[  457.620274] wlp3s0: RX AssocResp from 60:32:b1:95:2e:7e (capab=0x1411 status=0 aid=4)
[  457.620722] wlp3s0: associated
[  457.676781] wlp3s0: Limiting TX power to 27 (27 - 0) dBm as advertised by 60:32:b1:95:2e:7e
inxi -Fxxx output regarding network
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    vendor: Hewlett-Packard RTL8111/8168/8211/8411 driver: r8169 v: kernel pcie:
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp2s0 state: down mac: 10:62:e5:82:69:96
  Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
    vendor: Hewlett-Packard driver: rtw_8723de v: N/A pcie: speed: 2.5 GT/s
    lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:d723 class-ID: 0280
  IF: wlp3s0 state: up mac: 80:c5:f2:bf:38:97
ip address output
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
2: enp2s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether 10:62:e5:82:69:96 brd ff:ff:ff:ff:ff:ff
3: wlp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 80:c5:f2:bf:38:97 brd ff:ff:ff:ff:ff:ff
    inet 1.92.168.110/24 brd 1.92.168.255 scope global noprefixroute wlp3s0
    inet 192.168.1.106/24 brd 192.168.1.255 scope global dynamic noprefixroute wlp3s0
       valid_lft 3389sec preferred_lft 3389sec
freaky
#4 2024-08-17 08:51
Raintania wrote:
ip address output
There are two "inet" lines. Looks like your interface has been configured to have both a fixed (1.92.168.110) and an automatic (192.168.1.106) IP address but they belong to two different classes. Is this intentional?
Otherwise I would suggest to use Network Manager to fix the parameters of your connection or to delete and recreate it (be sure to copy the password first if you don't remember what it is).
You don't need an Internet connection to use Network Manager.
#5 2024-08-17 14:12
Raintania
hchiper wrote:
Raintania wrote:
ip address output
Alright thanks
freaky
