#1 2024-06-22 18:15
Manessa
2 GB RAM and Q4OS
Hello everyone, today I will tell you my experience of using Q4OS on a very weak hardware. On board my laptop there is 2 GB of RAM and a dual-core processor. Despite the fact that I have a 64-bit processor, I installed a 32-bit OS as the basis for my not a modern laptop. The first thing I did was install the basic system for this device. Regarding the choice of browser, everything was much easier. I installed Synaptic, and from there I installed 3 browsers for myself to compare them. And so htop showed me
Falkon- 400 mb
Netserf-150 mb
Cromium- 700mb
Seamonkey-350mb
Pale moon-230mb
Naturally, with 2 GB, it was difficult to open YouTube, other sites opened well, and I also have a netbook without the ability to insert RAM. So what conclusions did I draw for myself?
First, if you only have 2 GB of RAM, then install a 32-bit system, because a 64-bit system uses up memory faster for such computers
Second, use browsers such as NetSerf,Falkon,SeaMonkey,Palemoon
third and final, don't forget to connect Zram.Helps a lot
I hope with my post I will answer some of the questions about how suitable Q4OS is for a weak computer
Falkon- 400 mb
Netserf-150 mb
Cromium- 700mb
Seamonkey-350mb
Pale moon-230mb
.Yes, Q4OS is very well suited for such computers. The system works faster than Windows 7 for such computers
#2 2024-06-28 16:01
supra2jz
Re: 2 GB RAM and Q4OS
I am using the 64bit Q4OS version with 3GB RAM on an old C2D CPU and YouTube works perfect with latest Firefox 127 version, in fact everything works normally fast.
Q4OS running on IBM ThinkPad T60 - C2D T7200, 3GB RAM, 128GB SSD / pockethacks.com / jdmedmparts.com
#3 2024-07-01 12:48
supra2jz
Go for it, Q4OS with Trinity DE works perfectly fine with 2GB RAM.
#4 2024-07-04 18:49
vanquishedangel
This may help, I fixed up and old dell d430 and ran Q4os on it until I tore the hd cable. Now I use it on a Samsung CB4. Here is the link to a few hacks/tricks I found and used.
https://www.q4os.org/forum/viewtopic.php?id=4430
#5 2024-07-30 23:43
Christopher633
Hey! I agree with you, Q4OS is a great choice for weaker hardware. I also have a laptop with 2 GB RAM and a dual-core processor. Using the 32-bit version is a good idea because it saves memory. I personally use Falkon and SeaMonkey as they are lighter on resources.
Regarding Zram, it really helps. Thanks to it, I can even watch YouTube without too many issues. Have you considered trying other lightweight desktop environments, like LXQt?
Regards,
Christopher633
#6 2024-07-31 01:34
Dell Latitude D430 was a great system and runs very well with Q4OS TDE. Even the KDE version runs very well on my Lenovo Thinkcentre M600 Tiny that uses a Pentium j3710 four core processor that runs at only 12W. Its no barn burner but and with 4gb of ram runs extremely well.
#7 2025-06-10 08:48
chrisjordon
Thanks for sharing your experience! It's always great to hear real-world use cases on older hardware.
Totally agree! Q4OS is a solid choice for low-spec machines. I've also found that going with the 32-bit version makes a big difference on systems with only 2 GB of RAM. The system just feels snappier, and memory usage is noticeably lower compared to 64-bit.
Your browser comparison was especially helpful! I’ve tried a few of those myself, and it really shows how important lightweight browsers are when working with limited RAM. One quick heads-up for anyone reading when you see memory usage listed as “Falkon – 400 mb” or “Chromium – 700 mb,” it’s easy to get confused between mb and mb. Some people use mb to refer to megabits (Mb) and others to megabytes (MB), even though they're very different. Most tools like htop report in megabytes (MB) and just for reference, 1 MB equals 8 Mb. So make sure you're reading those numbers in the right context!
Also, +1 for enabling ZRAM it really helps squeeze a bit more performance out of older machines with tight memory limits.
Appreciate your post it definitely answers the question of whether Q4OS is usable on weak hardware.
Short answer: yes, and surprisingly well!
