#1 2024-06-01 16:57
crodgers79
Is there a way to backup/restore all desktop customization settings?
I love Q4OS and especially the Trinity Desktop and how I can change it to look like the old Windows XP, fantastic! I was wondering though since I spend a lot of time tweaking the desktop settings to my liking is there any way to back them up? I find that sometimes when I'm applying a new setting unbeknownst to me it changes like three other things or resets the entire desktop and then I have to start all over.
   A way to backup my customized desktop sure would be nice!
Thanks in advance for any and all replies!
Chris R.
#2 2024-06-03 08:38
Re: Is there a way to backup/restore all desktop customization settings?
Chris R.
I love the trinity desktop too, I will try to help:
Most of the desktop settings are stored in these files:
~/.trinity/share/config/kdesktoprc (desktop general configuration)
~/.trinity/share/config/kickerrc (Kicker-specific: taskbar, KMenu, etc.)
~/.trinity/share/config/kdeglobals
Making a backup of these files and restoring them if needed should be sufficient.
However, depending on which settings you are referring to, there are many other configuration files in the ~/.trinity/share/config/ folder.
A useful trick to find out what changes when you adjust settings through the graphical UI is to open a terminal and use the following command:
inotifywait -r -m -e modify ~/.trinity/share/config/ | while read file_path file_event file_name; do echo ${file_path} ${file_name} event: ${file_event}; done
This command will display which files are being modified. If you open these files in an editor like Kate and try to undo/redo your settings, you will know exactly which string or value is changing.
Hope this helps smile
#3 2024-06-03 14:04
crodgers79
Thank you VERY much for taking time to explain that all to me! Very helpful!!
Appreciate your time!
Chris R.
#4 2024-07-30 23:13
Christopher633
This one helped me too! Thank you very much!!! Have a nice day!
Christopher633
