Request assistance fixing error code (1)
sudo apt-get update && sudo apt-get dist-upgrade
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
Hit:3 https://dl.winehq.org/wine-builds/debian bookworm InRelease
Hit:4 http://security.debian.org bookworm-security InRelease
Hit:6 https://packages.mozilla.org/apt mozilla InRelease
Hit:5 https://q4os.org/q4repo q4os-5-0-cn InRelease
Get:7 https://q4os.org/qextrepo bookworm-plasmalooks-cn InRelease [3,237 B]
Hit:8 https://q4os.org/qextrepo bookworm-firefox-cn InRelease
Fetched 3,237 B in 3s (1,170 B/s)
Reading package lists... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up linux-image-6.1.0-18-amd64 (6.1.76-1) ...
/etc/kernel/postinst.d/dkms:
dkms: running auto installation service for kernel 6.1.0-18-amd64.
Sign command: /usr/lib/linux-kbuild-6.1/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
applying patch cc_version_check-gcc5.patch...patching file conftest.sh
applying patch bashisms.patch...patching file conftest.sh
applying patch linux-2.6.34-dev_pm_info-runtime_auto.patch...patching file conftest.sh
applying patch 0033-refuse-to-load-legacy-module-if-IBT-is-enabled.patch...patching file nvidia-modeset/nvidia-modeset-linux.c
patching file nvidia/nv.c
applying patch ppc64el.patch...patching file nvidia/nvlink_common.h
applying patch fragile-ARCH.patch...patching file Makefile
applying patch use-kbuild-compiler.patch...patching file Makefile
patching file Kbuild
applying patch use-kbuild-flags.patch...patching file Kbuild
patching file nvidia/nvidia.Kbuild
patching file nvidia-modeset/nvidia-modeset.Kbuild
applying patch conftest-verbose.patch...patching file Kbuild
applying patch conftest-prefer-arch-headers.patch...patching file conftest.sh
Building module:
Cleaning build area...
env NV_VERBOSE=1 make -j4 modules KERNEL_UNAME=6.1.0-18-amd64...................(bad exit status: 2)
Error! Bad return status for module build on kernel: 6.1.0-18-amd64 (x86_64)
Consult /var/lib/dkms/nvidia-tesla-470/470.223.02/build/make.log for more information.
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
dkms: autoinstall for kernel: 6.1.0-18-amd64 failed!
run-parts: /etc/kernel/postinst.d/dkms exited with return code 11
dpkg: error processing package linux-image-6.1.0-18-amd64 (--configure):
installed linux-image-6.1.0-18-amd64 package post-installation script subprocess returned error exit status 1
Setting up linux-headers-6.1.0-18-amd64 (6.1.76-1) ...
/etc/kernel/header_postinst.d/dkms:
Building module:
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 11
Failed to process /etc/kernel/header_postinst.d at /var/lib/dpkg/info/linux-headers-6.1.0-18-amd64.postinst line 11.
dpkg: error processing package linux-headers-6.1.0-18-amd64 (--configure):
installed linux-headers-6.1.0-18-amd64 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-image-amd64:
linux-image-amd64 depends on linux-image-6.1.0-18-amd64 (= 6.1.76-1); however:
Package linux-image-6.1.0-18-amd64 is not configured yet.
dpkg: error processing package linux-image-amd64 (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-headers-amd64:
linux-headers-amd64 depends on linux-headers-6.1.0-18-amd64 (= 6.1.76-1); however:
Package linux-headers-6.1.0-18-amd64 is not configured yet.
dpkg: error processing package linux-headers-amd64 (--configure):
Errors were encountered while processing:
linux-image-amd64
linux-headers-amd64
E: Sub-process /usr/bin/dpkg returned an error code (1)I tried unsuccessfully:
sudo dpkg --configure -asudo apt-get -f installsudo apt-get upgrade --fix-missingsudo apt --fix-missing updateLast edited by ChasHenry (2024-02-17 02:45)
There is a problem when upgrading to the current kernel if you use nvidia drivers/firmware in Debian, a fix is on the way and there is nothing really for Q4OS or it's users to do until the next update, best advice would be to roll back to 6.1.0-17 kernel until it is fixed.
Thanks, will wait until the next update.
Just to update this, a new kernel build is available in the debian proposed-updates repository, I'm not sure if the devs have this repo available but the Debian wiki has some instructions that can safely be used HERE.
Thanks but it seems this repo is not (yet) available in Synaptic Package Manager.
You could use the instructions I linked (Debian Wiki) to enable it.
EDIT:
And as a btw, it is the nvidia driver package that will need to be updated and that will allow the kernel to install correctly, apologies for my previous mis-information about it being a kernel problem.
$ sudo add-apt-repository 'deb http://deb.debian.org/debian/ stable-proposed-updates main'
Repository: 'deb http://deb.debian.org/debian/ stable-proposed-updates main'
Description:
Archive for codename: stable-proposed-updates components: main
More info: http://deb.debian.org/debian/
Adding repository.
Press [ENTER] to continue or Ctrl-c to cancel.
Found existing deb entry in /etc/apt/sources.list.d/archive_uri-http_deb_debian_org_debian_-bookworm.list
Adding deb entry to /etc/apt/sources.list.d/archive_uri-http_deb_debian_org_debian_-bookworm.list
Adding disabled deb-src entry to /etc/apt/sources.list.d/archive_uri-http_deb_debian_org_debian_-bookworm.list
Hit:1 http://deb.debian.org/debian bookworm-updates InRelease
Hit:2 http://deb.debian.org/debian bookworm InRelease
Hit:5 http://deb.debian.org/debian bookworm-backports InRelease
Hit:7 http://deb.debian.org/debian stable-proposed-updates InRelease
Hit:9 https://packages.mozilla.org/apt mozilla InRelease
Hit:6 https://q4os.org/q4repo q4os-5-0-cn InRelease
Get:8 https://q4os.org/qextrepo bookworm-plasmalooks-cn InRelease [3,237 B]
Hit:10 https://q4os.org/qextrepo bookworm-firefox-cn InRelease
Fetched 3,237 B in 2s (1,727 B/s)
W: Conflicting distribution: http://deb.debian.org/debian stable-proposed-updates InRelease (expected stable-proposed-updates but got bookworm-proposed-updates)I can't figure out what went wrong.
You need to add non-free section to your source entry, this is mine
deb http://deb.debian.org/debian/ bookworm-proposed-updates main contrib non-free non-free-firmwareOffline
This is the entry of my sources.list
[img=FluxBB bbcode test]file:///home/karl/Desktop/Screenshot_20240217_sources.list.png[/img]
The entry of my my sources.list is:
This is the result of the update/upgrade
$ sudo apt-get update && sudo apt-get dist-upgrade
Hit:1 https://dl.winehq.org/wine-builds/debian bookworm InRelease
Hit:2 http://security.debian.org bookworm-security InRelease
Hit:3 http://deb.debian.org/debian bookworm-proposed-updates InRelease
Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
Hit:5 http://deb.debian.org/debian bookworm InRelease
Hit:6 http://deb.debian.org/debian bookworm-backports InRelease
Hit:8 https://packages.mozilla.org/apt mozilla InRelease
Hit:7 https://q4os.org/q4repo q4os-5-0-cn InRelease
Get:9 https://q4os.org/qextrepo bookworm-plasmalooks-cn InRelease [3,237 B]
Fetched 3,237 B in 2s (1,344 B/s)
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.The warning notice relating to "Conflicting distribution" has disappeared
I am not so sure about the unchecked items in Repository...
[img=FluxBB bbcode test]file:///home/karl/Desktop/Screenshot_20240217_Repositories.png[/img]
and Discovery
[img=FluxBB bbcode test]file:///home/karl/Desktop/Screenshot_20240217_Settings - Discovery.png[/img]
edit: I can't figure out on adding screenshots. The unchecked items I am referring to in Synaptic are:
deb-src http://deb.debian.org/debian/ stable-proposed-updates main
and in Discovery:
Debian Stable proposed updates (main)
Debian Stable proposed updates (main) Sources
You will still need to add the non-free section of the repository, and then run
sudo apt update && sudo apt upgradeOffline
Thanks, I did that but not working - running around circles - Synaptic producing errors - I gave up fixing and re-installed - it's much faster!
Thanks again... Cheers.
so long as you got it working again that's all good ![]()
