#1 2024-01-04 20:45
DricC
Brightness back to 100% at every pc wake up
Just installed the latest version of Trinity on my 5 year old HP laptop. Everything works out of the box. Just one little thing: brightness is set back to maximum every time I reopen my laptop. I usually have it around 30%. It keeps jumping back to 100%. Anyone else experiencing this? Thanks in advance.
#2 2024-01-05 13:48
Re: Brightness back to 100% at every pc wake up
FWIW, you can quickly tone down brightness by scrolling your mouse wheel over the power status tray icon...
#3 2024-01-05 14:36
DricC
That's handy. I like that. Also works scrolling on the touchpad while the cursor is on the icon.
#4 2024-01-06 13:59
nightflier
You can create a startup script to set your brightness. Some experimenting will be necessary to figure out what works for your hardware/software combination. On my laptop I can use command "sudo echo 5 > /sys/class/backlight/acpi_video0/brightness" to select a dim setting. It accepts numbers from 0 to 15.
Check out this guide: https://askubuntu.com/questions/149054/ … via-script
#5 2024-12-27 18:31
DricC
Hey guys, I finally got it solved! by unchecking some checkmark in the KPowersave settings, accessible by right-clicking the panel icon and selecting Configure KPowersave
