#1 2023-12-11 18:46
[Solved] Very slow download speed from q4os repository
Last month I have noticed, that download speed from q4os.org repository became very slow. About 250-400 Kilobytes per second.
https://drive.google.com/file/d/1aiyVq- … sp=sharing
https://drive.google.com/file/d/1ah4QGm … sp=sharing
Why? I have not noticed this before.
Also, this is not my Internet connection problem. I have internet speed about 25-30 Megabytes per second.
https://drive.google.com/file/d/1amIHFF … sp=sharing
Also, download from ftp.se.debian.org goes very fast - 3-4 MB/s.
#2 2023-12-12 10:50
Re: [Solved] Very slow download speed from q4os repository
Downloads from q4os.org go fine here at speed 11MB/s, maybe some temporary glitch ?
$ wget http://www.q4os.org/qextrepo/pool/main/f/firefox/firefox_120.0-2+build1~deb12u1_amd64.deb
firefox_120.0-2+build1~deb12u1_amd64.deb    100%[========>]  62.09M  11.1MB/s  in 5.6s
#3 2023-12-12 21:46
Today, I have tried again using your command to download from q4os.org. The download speed was 840 KB/s, which was a bit faster but still very slow (attachment). Also, I have tried to download at night, when Internet traffic is less intensive and servers are not so loaded as in daytime. So, I suppose, that it is not a temporary glitch.
#4 2023-12-12 21:52
Tried again, and download speed became even slower sad
My Internet speed is 48Mbps. (attachment).
#5 2023-12-13 08:29
I tried the same download as Q4OS Team after he posted his response, and I tried just now. The speed are 14 and 12 MB/s smile
Between Q4OS' server and your computer, the wire is long and there are many intermediate machines, whose one might be responsible. You might consider using
traceroute www.q4os.org
#6 2023-12-13 08:50
Your speed test involves another server (DEAC in Riga? which is nearby where you live) and a different (shorter) route, involving other intermediate machines, if any. Don't be too suspicious on Q4OS server at first.
#7 2023-12-13 10:15
We have tested more thoroughly and also noticed intermittent drops in download speed, however not as noticeable as @Rademes. So we will try to ask our server provider to check it.
#8 2023-12-13 17:32
@Q4OSTeam, can you tell me in which city the q4os.org server is located, so I could perform a proper SpeedTest?
#9 2023-12-13 17:44
Czech Republic, Prague
#10 2023-12-15 11:10
I have tested my internet speed, using two servers, located in Prague. Inernet speed is OK. See attachments.
Traceroute is in attachment.
#11 2023-12-15 18:35
OK, the delays look like good. I have nearly the same.
Now what about your download speed from q4os.com with this situation? Better? Still slow?
#12 2023-12-16 14:32
Very bad! Still only about 300 KB/s sad See attachments.
But the traceroute is good.
I am sure, that the problem is in q4os.org server, and not in my Internet, because downloading from another servers is still very fast. Only q4os.org server has so slow download speeds. If I would be confident, that the problem is in my Internet connection, I would not create this topic.
#13 2023-12-16 17:33
[snip]
firefox_120.0-2+build1 100%[============================>]  62,09M  4,45MB/s    ds 7,9s
2023-12-16 17:25:30 (7,83 MB/s) — « firefox_120.0-2+build1~deb12u1_amd64.deb » sauvegardé [65105832/65105832]
We could use crontab to launch the same download at the same time tonight?
#14 2023-12-16 18:38
I do not know, how to use cron, and now I do not have time to learn, since I have a lot of work, sorry.
However, a have tested again and again I have this very slow speed...
On your first test, you had speed 12 MB/s, but today you had only 4,45 MB/s. So, the speed dropped significantly for you too.
Q4OSTeam also noticed speed drops. So, there is something wrong with q4os server.
#15 2023-12-16 18:48
Same download 1 minute after your last post and high speed (3,37 MB/s) for me.
Are you saving the downloaded file to a slow device?
#16 2023-12-16 19:11
Downloaded again and saved to a slow device (USB2) with the -O option. Download terminated before the file had been written, but the speed was... 13,7 MB/s (yes, thirteen)!
#17 2023-12-16 20:54
I have noticed, that when I test my internet speed using Speedtest.net in Single connection mode, it is slower, than in Multi connection mode. Still not so slow to be 300 KB/s...
#18 2023-12-19 12:06
We can confirm that some geographic locations may experience download speed issues from the q4os.org server. Although at a somewhat reduced speed, the data transfer will still be uninterrupted and reliable. The solution will be more complex, so we need to work with our data provider to resolve it.
#19 2023-12-19 13:46
Today I have better download speed - 1.7MB/s. Not as fast as it could be, but acceptable.
That`s good to hear. When download speed becomes very slow, I always afraid, that the download could be interrupted. I have had such situations in the past.
