#1 2023-12-08 00:44
dodogames
Debian bookworm updates repo are invalid
Hi, so as usual i was using Q4OS and everything seemed to be fine until i decided to run `sudo apt update` at terminal to check for updates or so. Upon doing that, every repo seems to have been read by the system until it reached to debian bookworm updates where it stopped with the following error:
E: Release file for http://deb.debian.org/debian/dists/book … /InRelease is not valid yet (invalid for another 6h 45min 51s). Updates for this repository will not be applied.
Is this normal or do i have to take action to fix this?, otherwise i'm not sure on what does that mean personally. To be frank, i didn't tried to do anything that caused this problem so i'm kinda clueless.
#2 2023-12-08 09:05
Re: Debian bookworm updates repo are invalid
Are you running in a virtual machine ? If so, it's normal as you restore a virtual machine from a snapshot. You only need to synchronize guest time or reboot to suppress the message. If you are running on a real hardware, just check and synchronize date and time.
#3 2023-12-13 16:52
dodogames
It seems to have solved by itself. Thanks for help attempts anyway
#4 2023-12-17 18:58
Zapruder
Solved by itself.
