#1 2023-08-17 15:09
Viggen66
Q4OS with kernel 6.2
Dear all
Is there a way to install q4os with kernel 6.2,simple because it brings embedded support for my wifi adapter, instead of having to install third party driver.
Thanks.
#2 2023-08-17 18:06
Re: Q4OS with kernel 6.2
Please try this solution: https://www.q4os.org/forum/viewtopic.ph … 320#p24320
It has worked for a topic starter.
The only thing is, instead of
deb http://deb.debian.org/debian bullseye-backports main contrib non-free
line you will have
deb http://deb.debian.org/debian bookworm-backports main contrib non-free non-free-firmware
line if you are using Q4OS Aquarius.
#3 2023-08-17 19:20
Viggen66
Thanks gonna try this solution, yes on the topic, I use my smartphone with usb to fetch the dependencies to install third party driver, a brand new kernel after version 6.1, I don't need to do anything since it supports the wifi.
#4 2023-08-19 15:35
Viggen66
Read about Xanmod and Liqourix kernel, which are up to version 6.4 are they any better than those backported kernels from Debian sources?
Thanks
#5 2023-08-20 14:49
nightflier
I can vote for Xanmod. I do not notice any performance differences, but the kernels are bleeding edge and stable.
