#1 2016-02-28 16:09
CaptNoize
Theme and Font size changer
I downloaded Theme and Font size changer from the Mozilla FireFox/Thunderbird add on site,a while back. It installed on both FireFox and Thunderbird  emails. I recently did a update,both thru the console,and the update manager. Now, the Theme size changer is gone,and when I try to download it again, I get the window that says it's no longer compatible with my older machine.?? It was functioning fine before...did they change something..? What would be a comparable recommendation for this.?
#2 2016-02-29 02:53
CaptNoize
Re: Theme and Font size changer
OK.  Thanks, CC. This has been real confusing.My newer machine, which was built in 2004,shouldn't have this problem. It ended up deleting the font/theme changer from that computer. When I tried to reinstall it, the program downloaded to a zip file...ugh..instead of installing. Like you,,at that point, I also gave up. It was asking me what the file should be installed as..forget it... I'm done.
#3 2016-02-29 03:09
CaptNoize
I also never did find out why I don't get email sounds from Thunderbird....has anyone figured that out yet...?
#4 2016-03-01 02:10
CaptNoize
Well,thanks for trying,anyway. They never replied to any of my emails. I guess I don't meet their criteria.
