#1 2023-04-14 11:34
ivandebcn
Problem with synaptic
Hello, I'm new in Linux systems and I'm a bit lost.
I am trying to enter Synaptic but these mistakes come out:
Predomination 1 Bad specified in the list of sources /etc/apt/sources.list.d/librewolf.sources (type)
The lists of sources could not be read.
Does anyone know what can I do to solve it?
I have played something on the konsole and now I don't know how to solve it
I am using Q4OS Gemini
Thank you.
#2 2023-04-15 06:36
Re: Problem with synaptic
Debian sources files must end in .list
Open Konsole
sudo mv /etc/apt/sources.list.d/librewolf.sources /etc/apt/sources.list.d/librewolf.list
sudo apt update
If it is still objecting
sudo nano  /etc/apt/sources.list.d/librewolf.sources
Put a # at the start of any lines in the file
Ctrl O to save
Ctrl X to leave
sudo apt update
which should complete without any errors
Use synaptic as required
#3 2023-04-15 07:13
It seems you tried to install LibreWolf but the installation wasn't successful. If you followed instructions given on the Installation page, you probably created more files on your system than only librewolf.sources.
I suggest you to
  • First (try to) uninstall LibreWolf:
    $ sudo apt autoremove librewolf
  • Then remove its repositories from your system. See the instructions at the end of the Installation page.
    Select carefully the full 10 lines command (sudo rm /f ...), copy/paste it into Konsole and press Enter.
    Terminate with
    $ sudo apt update
