#1 2023-04-15 02:28
PeterLinu
[SOLVED] Synaptic on desktop
See attached.
I already have Synaptic inside the menu which is fine for the limited time I use it. I don't know how to remove it when booting up.
Any help appreciated.
#2 2023-04-15 06:51
Re: [SOLVED] Synaptic on desktop
It would seem that you have synaptic in autostart somewhere.
The most likely place you have put it will be in be  ~/.trinity/Autostart
You'll find either a symlink or a copy of the synaptic.desktop file
Remove it.
#3 2023-04-15 07:06
PeterLinu
Thanks. That worked. However what remains is a file on the desktop called '.directory'. How do I stop that loading on boot?
#4 2023-04-15 12:14
.directory files are used to provide the icon information for the directory in which they reside.
If you look at the other folders on your machine you'll see them (they're hidden files) but can be read as text.
Right click on Desktop>Configure Desktop>Behaviour>File Icons> Uncheck 'Show hidden files'>Apply
#5 2023-04-15 12:39
PeterLinu
Fixed, thank you.
