#1 2023-03-16 15:24
just1acc
Change default file association / open with menu for pdf
After removing okular, can't get rid of default file association of okular. Neither could remove it and ksquirrel from open with menu. Also could not set kGhostview as default (could not find it).
Q4OS Trinity.
Please guide. Considering a newbie. As my little bit of linux knowledge never go beyond Mint (Mate).
#2 2023-03-16 18:01
ydek
Re: Change default file association / open with menu for pdf
Hello!
On Trinity you can also try to open PDFs files with program KPDF (PDF viewer).
#3 2023-03-16 18:14
just1acc
...and in chrme too. However it does not solve the issues.
#4 2023-03-16 18:22
ydek
Tried in Konqueror Right-click on the file PDF, choose Open With... and select the program ?
#5 2023-03-16 18:22
just1acc
Got solution. From proprties there is an icon for those settings in Trinity.
Please mark as solved.
#6 2023-03-16 18:27
ydek
Glad you found the solution.
#7 2023-03-16 18:31
Only you can do that: edit your first post and modify the subject.
#8 2023-03-17 04:14
just1acc
Probably there is restriction for new members for editing thread. I can't change chrome spelling too. Anyway, thank you once again.
