#1 2023-03-16 02:19
PeterLinu
[SOLVED] Conky
Hiyall,
I want to replace the default menu conky with my own conky.
How?
#2 2023-03-16 09:02
Re: [SOLVED] Conky
Save your conky file as ~/.conkyrc
#3 2023-03-16 09:15
PeterLinu
Re: [SOLVED] Conky
and where do I then put it?
#4 2023-03-16 09:49
Re: [SOLVED] Conky
@PeterLinu
You have opened several topics about your Conky installation. Please stop opening duplicate threads. Try to make only one topic active not to tend to clutter the forum.
#5 2023-03-16 09:54
PeterLinu
Re: [SOLVED] Conky
All others have now received a notation [SOLVED], etc. This is the only current one.
In future I will stick to one. My apologies.
#6 2023-03-16 10:01
Re: [SOLVED] Conky
Ok, thanks. Focusing more info in one topic may bring more relevant info and solutions. Anyway, notating completed topics [SOLVED] is a good point.
#7 2023-03-17 09:18
Re: [SOLVED] Conky
~ = /home/<user>/
#8 2023-03-18 03:34
PeterLinu
Re: [SOLVED] Conky
Dai,
I needed to re-install Q4OS. I then took your advice and conky now works the way I want.
Thank you.
#9 2023-03-18 11:00
Re: [SOLVED] Conky
You are welcome.
