#1 2023-02-22 22:54
0ver2
[SOLVED]Can"t find 'OpenJDK Java 11 Runtime' in 'Open with'
Just installed 'default-jre' in apt, but when trying to open a .jar program file, there is nothing in the list of 'Known Applications' that hints to Java.
#2 2023-02-24 18:41
Re: [SOLVED]Can"t find 'OpenJDK Java 11 Runtime' in 'Open with'
How are you trying to "open" the .jar file? I usually do this via terminal:
1. Launch konsole (terminal)
2. Navigate to your .jar file's path, right-click on a blank space and select "open terminal here".
3. In the terminal run this:
java -jar file_name.jar
It's always worked for me.
Hope this helps! smile
#3 2023-02-27 01:26
Synaptic has OpenJDK Runtime already installed and other packages are available as well.
Q4OS KDE 5.xx  Lenovo M73 Thinkcentre Tiny
#4 2023-03-03 16:02
0ver2
Yes it did. Strangely it worked only over terminal, when I choose GUI context menu point 'Open with...' (Konqueror), it only flashes a terminal window in response and nothing further happens.
Good to know, thanks!
#5 2023-03-03 16:03
0ver2
Konqueror is pretty strange
#6 2023-03-03 22:59
Browser or file manager?  File manager is pretty good but the browser is completely hopeless and simply too far behind to be of any value.
