#1 2023-02-15 00:39
PeterLinu
Taskbar [SOLVED]
Hiyall,
I want to put icons on the taskbar of regularly-used applications like; browser, screenshot, terminal. I can't work out how to do it.
Please help.
#2 2023-02-15 04:00
vanquishedangel
Re: Taskbar [SOLVED]
I switched to LXDE but I managed to do it  in trinity before hand. You need to right click on the task bar by the other buttons and select add items. when the menu pops up you can choose what applications by going into "Application Launch Bar Settings" or highlighting application launch bar and selecting preferences. then you choose what applications to put on the application launch bar from the menu system and click add I believe.
#3 2023-02-15 04:39
PeterLinu
thank you vanquishedangel,
you reminded me of what I did configuring every other Linux OS!
#4 2023-02-15 09:16
It should be quite easy. Unlock the panel > Right mouse click on the panel > select Add application to panel
