#1 2023-02-13 06:41
rafaelramos
PHP 8 on Q4OS
The official Q4OS (and Debian) repository provides PHP 7.4 by default, which is already well outdated.
Does anyone know a safe way to install PHP 8 on Q4OS?
#2 2023-02-13 12:53
Re: PHP 8 on Q4OS
If you can't wait Q4OS 5 release (based on Debian 11 and coming with PHP 8.2), you can follow instructions from  the PHP Manual: Installation and Configuration.
#3 2023-02-13 18:01
rafaelramos
Re: PHP 8 on Q4OS
Hello hchiper,
I was looking for a more simplified way through apt-get...
I found this tutorial here, but I haven't tried it yet:
https://computingforgeeks.com/how-to-in … ian-linux/
#4 2023-02-20 06:25
rafaelramos
Re: PHP 8 on Q4OS
I installed PHP 8 on Q4OS 4.11 in a simple way with "apt-get"...
Adding the sury.org apt:
sudo apt update
sudo apt install -y lsb-release ca-certificates apt-transport-https software-properties-common gnupg2
echo "deb https://packages.sury.org/php/ $(lsb_release -sc) main" | sudo tee /etc/apt/sources.list.d/sury-php.list
wget -qO - https://packages.sury.org/php/apt.gpg | sudo apt-key add -
Installing PHP 8:
sudo apt update
sudo apt install php8.0
php -v
Installing the most important extensions:
sudo apt install php8.0-{mysql,cli,common,imap,ldap,xml,fpm,curl,mbstring,zip,sqlite3}
Disabling PHP 7.4 and enabling PHP 8.0:
sudo a2dismod php7.4
sudo a2enmod php8.0
sudo systemctl restart apache2
