#1 2023-01-19 11:14
kde35
Installation process blocked (Q4OS Gemini, Trinity, live ) [Solved]
Hi, I have tried Q4OS Gemini live DVD which worked fine, I tried to install, but it looks like the installation process got stuck with
Applying Desktop profile, it may take a while, please be patient
>[7819]: current message > Download complete and in download only mode
(the number in [ ] augment approximately by 1 per seconds).  htop shows 300 % CPU usage (12-cores) on command calamares and 100 % on qsinst.  Is this a normal behavior during installation process (I have internet connexion with optical fiber and ethernet for LAN), or has something gone wrong ?  Thank you in advance
#2 2023-01-19 11:25
kde35
Re: Installation process blocked (Q4OS Gemini, Trinity, live ) [Solved]
I checked a bit further, what is "hanging" seemed to be
 ps -u root -f  | grep qs
root       67360   54931 99 09:04 ?        02:11:26 qsinst /tmp/.awkrr15ljkroot.tmpdir//setup_q4os-firefox_4.2-a1_all.esh
I lost my patience and I killed the process
kill -9 67360
and installation terminated.  Let's hope the system won't be corrupt...
#3 2023-01-19 11:26
What desktop profile did you select upon the install process ?
#4 2023-01-19 11:59
kde35
If I remember correctly I chose "Desktop installation" (had choice between Desktop, server, live, something like that).  If you are talking about Desktop environment, I didn't change anything, so it is trinity.
Now I can boot on installed system,  installation of firefox blocks on "Searching for language packages ..." (which presumably was blocking the installation).  I should probably mark this as solved and open a new thread?
#5 2023-01-19 12:13
Yes please, open a new topic.
#6 2023-01-19 12:16
One more question, what language did you select ?
#7 2023-01-19 14:58
kde35
en_GB
