#1 2022-11-15 14:45
xdexx
Error during intallation
Trying to install Q4OS on my ThinkPad S540. Installation from USB-3 stick to Samsung T3 SSD (USB-C).
Always results in an error during partitioning (Automatic install option).
A screenshot of the error is here:
error
Any help will be very much appreciated!
Cheers from Holland!
#2 2022-11-15 14:46
Re: Error during intallation
The screenshot cannot be opened. Your account has been promoted to be able to attach files and links, please edit your post and try it once again.
#3 2022-11-15 14:49
xdexx
If the screenshot is not showing, the error is:
Installation failed
The installer failed to make partition on disk........
Create new partition (300.00 MiB, fat32) on '/dev/sdb'
Job: Create new partition on device '/dev/sdb'
Failed to add partition 'New Partition' to device '/dev/sdb'.
Samssung SSD is brand new!
#4 2022-11-15 14:51
xdexx
Link to error screenshot:
https://www.dropbox.com/s/kqsz6xe3zxvcl … r.jpg?dl=0
#5 2022-11-17 21:04
Unfortunately, I don't have an answer to your problem, but it seems strange that the automatic installation tries to create a fat32 partition. Did you retry to install?
#6 2022-11-18 07:21
If the SSD has never been used, I would use Gparted from the Q4OS boot media to create a partition table on the SSD. One thing bothers me. You say the SSD is connected via USB-C. Is there are hard drive in the laptop as well? If so the SSD would probably be /dev/sdc - so you need to make doubly sure you know what drive is what.
#7 2022-11-18 16:30
xdexx
Thanks for looking at my problem!
The laptop has no internal HD. Samsung SSD is connected via USB-3, not C.
It seems to be a problem with this particular version of Calamares installer.
#8 2022-11-18 16:35
xdexx
Arco Linux has a video about this problem and how to fix it, but nothing I have tried helped...
https://www.youtube.com/watch?v=iSNa9XTeDKE&t
#9 2022-11-18 17:31
@xdexx
You can also try to use the "install-cd" https://www.q4os.org/downloads1.html , as it features Debian installer instead of Calamares. It'll be possible to install Plasma desktop using Deskop profiler. Yo're welcome to post back a result here.
