#1 2022-09-14 19:13
RedSearch
How do I remove this dpkg warning ?
How do I remove this error?
dpkg: warning: files list file for package 'matlab-support' missing; assuming package has no files currently installed
#2 2022-09-20 17:29
Re: How do I remove this dpkg warning ?
Here is written, that you have to reinstall package matlab-support. If it exists in repository, then run sudo apt update && sudo apt install --reinstall matlab-support
#3 2022-09-21 11:19
alphayash
thanks for the info it helped me .
