#1 2021-09-20 23:54
acrizona
First install
Where is the install instructions ?
I have  Q4OS 3.14 R5 32bit  CD.
It boots with 1 choice: INSTALL.     3 hours later,,, install is done + remove CD + GRUB boots to some ttyDOS  ????
Now what ?
#2 2021-09-22 11:12
Re: First install
Maybe your computer is short of RAM.
The minimal hardware requirements:
Plasma desktop - 1GHz CPU / 1GB RAM / 5GB disk
Trinity desktop - 300MHz CPU / 128MB RAM / 3GB disk
Can you describe your hardware (CPU, RAM, HD/SSD, Internet connection) and what desktop you have installed (Plasma or TDE/Trinity)?
#3 2021-09-22 19:45
acrizona
Re: First install
HP Pavilion N3250 laptop, built in the last century !     Was running Puppy using 10BaseT, but no drivers for new WiFi card.
I installed Sllitaz using old pcmcia WiFi. Works fine,  Old folks happily use Thunderbird eMail. Old FireFox is too s-l--o-w !
When I down-loaded Q4, and booted the CD, first noticed that Q4 is install ONLY (no demo like all others).
Where would I find  what desktop "I installed" ?
Whats Q4 best lightweight browser ?
#4 2021-09-23 07:26
Re: First install
CPU speed?
RAM size?
HD (no SSD) I presume? This can partly explain why install take so much time.
And if some stuff was downloaded during install, the 10baseT connection (ie 10 Mbits/s) can also partly explain the duration.
I believe that only Trinity / TDE is available with Q4OS 32 bits version (last link on the downlaod page).
Check if your hardware fulfills the minimum requirements (see my previous reply).
I presume the problem is there. In this case you might consider upgrading your system (RAM, SSD, if avaiable) if you consider it is worth to do.
#5 2021-09-23 13:01
Re: First install
Now what ?
That one is a bit old, I suggest trying this one instead https://sourceforge.net/projects/q4os/f … o/download which is the latest release. Or if the word testing seems a bit scary to you, wait till Sep 27 when stable gets released. However, I've been using testing for some months now with no issues, though the 64-bit one.
Hope this helps! smile
#6 2022-09-17 20:38
acrizona
Re: First install
Finally !    q4os-3.14-i386-install.r5.iso    onto Compaq Presario 2100 512m AMD 'clunker'.
Q4/Konqueror/Trinity suits old laptop(s) perfect !
I have six old machines waiting on suitable OS.    This is the best to-date.
We can finally toss the 50 other old LinuxII   (plural?)  CD distros.
Thank you & kudos to this forum !
