I'm trying to run onedrive as a service. I install it through apt install onedrive and everything seems to be ok but the service is inactive after reboot. I was trying to run this service on system load automatically but I failed...
I run it with this commands:
systemctl --user enable onedrive
systemctl --user start onedrive
Any one know how to do it?
systemctl status --user onedrive:
onedrive.service - OneDrive Free Client
Loaded: loaded (/usr/lib/systemd/user/onedrive.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2022-09-08 11:02:22 CEST; 5min ago
Docs: h t t p s : //github.com/abraunegg/onedrive [edited for this post]
Process: 933 ExecStart=/usr/bin/onedrive --monitor (code=exited, status=3)
Main PID: 933 (code=exited, status=3)
CPU: 50ms
onedrive.service:
[Unit]
Description=OneDrive Free Client
Documentation=h t t p s : //github.com/abraunegg/onedrive [edited for this post]
After=network-online.target
Wants=network-online.target
[Service]
Restart=on-failure
RestartSec=3
RestartPreventExitStatus=3
[Install]
WantedBy=default.target
To test I installed it, looks like the version in Bullseye is simply too old to work.
WARNING: Your onedrive client version is obsolete and unsupported. Please upgrade your client version.
Q4OS Trinity machine -Dere v14s. Intel Celeron N5095, 16GB LPDDR4, 512 GB SSD, Intel Jasper Lake GT1, Garbagetek 8822CE Wifi 5 + BT 5.0
It could be the reason, but when I run it manually the service works fine until next reboot and I have to run it again.
I tried to add startup script (startup.desktop) but the starting commands doesn't work
only onedrive --monitor is running from the startup script, and again I have to enter systemctl commands manually. Is there a way to run them on a system startup?
Please follow the correct process for authenticating and starting the client via systemd is as follows:
Install the client correctly
Authorise the client correctly
Validate your client configuration
Test your client configuration
Enable systemd service as required
The reason why the service is not starting up is that most likely the client has not been authorised correctly.
To debug further, enable system logging (logging to a log file) and increase the verbosity of the client when running, by modifying the systemd scripts to include --verbose
If you still cant get this to work correctly, raise a discussion on GitHub for support.
Do not install the client from the default Debian repositories. It contains out-of-date client software that contains bugs which have been fixed, thus is obsolete and unsupported - this is why you get this message.
You must install the client the correct way on Debian and Ubuntu platforms following the explicit instructions within ubuntu-package-install.md as per the GitHub repository.
Ok I resolved it in a different way. I couldn't win with OneDrive and I installed Insync which is IMHO the easiest solution.
