#1 2022-09-05 10:48
ForestHawk
Discover Update Issue warning
When I clicked on the latest system updates icon this morning i got an
Update Issue screen popped up on the KDE desktop before even entering Authentication.
Cannot remove system package WARNING.
You are trying to remove the following essential packages:q4os-welcome (due to q4-os desktop)
Then doesn't update anything.
System Updates showed
q40s-cpuq5
q4os-desktop
q40s-welcome-common
q4os-welcome5
Is this update only for updating from the terminal?
Cheers
Energy Flows where you Intention Goes.
#2 2022-09-05 11:33
Jilt
Re: Discover Update Issue warning
I am having the same issue
#3 2022-09-05 13:43
Yes, you need to update from terminal:
$ sudo apt update
$ sudo apt dist-upgrade
That should pass fine and Discover will be able to perform updates again.
#4 2022-09-05 13:51
@ForestHawk
What Q4OS version do you use ?
#5 2022-09-05 16:31
ForestHawk
Tnx @q40sTeam
Version I'm using is 4.10 Gemini  KDE and running the Terminal did the trick.
Cheers
