Have an old Toshiba Satellite A135-S4447 32 bit Intel Core Duo T2250 processor, 1024mb SDRAM I'd like to try Q40S on. It appears there is not a "live" 32 bit Q40S program available to "try" Q40S out. I've searched the forum and haven't found a solution perhaps because of my search terms?
Suggestions on how to try Q40S out would be appreciated.
Thanks
You can first try to use the 64-bit Trinity Live system. I think that should work as well.
or replace the original SATA hard drive with an SATA SSD drive and install the 32-bit Trinity system. You can always go back when you reinstall your original hard drive.
No, OP is correct. A Core Duo (not Core2 Duo) T2250 is a 32-bit processor. It's incapable of 64-bit instructions.
thank you for the correction. You know, since I always have a Q4OS live stick with me, I just try that out. But you are right.
