#1 2022-07-03 04:26
goldbergeliah
[SOLVED] Opera problem
Hello All!
For sometime I have not been able to update / upgrade or install any file as I keep getting the fallowing error on console:
ali@ali:~$ sudo apt-get update
N: '/etc/apt/apt.conf.d/'  '20auto-upgrades.ucf-dist' is not a valid file extention and it is ignored.
E: Signed-By crushing set of values (source https://deb.opera.com/opera-stable/ stable: /usr/share/keyrings/operabrowser-keyring.gpg != )
E: source list cound not be read.
I am almost sure that the problem is related to Opera browser that I tried to install but messed up. Even synaptic is giving the same error and do not work.
System info: Q4OS Bullseye Plasma
Linux 11
Your advises please...
#2 2022-07-03 05:58
Re: [SOLVED] Opera problem
First you need to edit out any sources related to Opera
Second you need to sort out the name and contents of the 20auto-upgrades file.
If you use Synaptic then open it and go to Settings>Repositories and uncheck anything related to Opera
If you use Discover or Muon or whatever then just do it there instead.
20auto-upgrades controls part of the unattended upgrades process.
It contains 2 lines which by default in Plasma are:-
APT::Periodic::Update-Package-Lists "1";
APT::Periodic::Unattended-Upgrade "0";
In the folder /etc/apt/apt.conf.d/ look for files with the name 20auto-upgradesxxxxx
There should only be one and it is just 20auto-upgrades - anything else containing that name is not needed.
If 20auto-upgrades.ucf-dist contains the lines above then just rename it to 20auto-upgrades
If it needs editing to correct it then do so.
This is puzzling as I have never come across that file being touched by any software installation.
#3 2022-07-03 21:12
goldbergeliah
Hello Bin!
I can not start Synaptic as it gives the error message as
E: Signed-By clashing value set (source https://deb.opera.com/opera-stable/ stable: /usr/share/keyrings/operabrowser-keyring.gpg != )
E: Source list couldn't be read.
E: _cache->open() failed, please report
Can I not just delete everything about Opera? I don't need it.
#4 2022-07-04 06:14
OK then go to /etc/apt/sources.list.d
You should see something like opera.list which you could just edit and comment out the lines with a #
If that is not there then you may need to look in /etc/apt/sources.list for a line that mentions opera and remove/comment out that line
Alternatively open /etc/apt in Dolphin and use Tools>Open kfind
Look for files *.list contains opera - not case sensitive
The editing can be done by right click>open with kwrite. When you save you'll be asked for your sudo password.
#5 2022-07-10 06:20
goldbergeliah
Dear Bin,
The problem seems to have been solved.
As you advised I searched for the file in the /etc/apt/sources.list.d. The first one to be noticed was
"q4p-opera-20220612xxxxx-Rlu.list"
Inside the file, there were 3 lines and the last one was
"deb http://deb.opera.com/opera-stable/ stable non-free"  which was not commented. I just commented it and now I don't get any error messages and also I can update with no issue.
Thanks a lot for your help!
