#1 2022-06-25 20:29
iaddo91
"Gestore pacchetti" don't work
Hi, when i open "gestore pacchetti" (this is italian traduction, i don't know the name of this in english), the system give me this error:
E: Impostati valori in conflitto per l'opzione Signed-By riguardo alla sorgente http:// linux.teamviewer.com/deb/ stable: /usr/share/keyrings/q4a-teamviewer.gpg !=
E: Impossibile leggere l'elenco dei sorgenti.
E: _cache->open() failed, please report.
Recently i just added teamviewer repository to install it, with commands:
qrepoadd --gui --> than i selected "teamviewer", and i write:
apt update
then i installed teamviewer but "gestore pacchetti" doesn't work now.
What can i do?
#2 2022-06-26 06:05
Re: "Gestore pacchetti" don't work
"gestore pacchetti" is package manager
After you ran qrepoadd --gui --> teamviewer you should have seen something like this:-
sudo qrepoadd --gui
[sudo] password for robin:
building cache, wait a moment please ...
Added repository: deb http://linux.teamviewer.com/deb stable main
Updating APT keyring - /usr/share/apps/q4os_system/q4p_keyring/q4a-teamviewer.pub - Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
OK
Keyring file: /usr/share/apps/q4os_system/q4p_keyring/q4a-teamviewer.pub
Repository file: /etc/apt/sources.list.d/q4p-teamviewer-20220626055436-Rnq.list
From the look of your output the keyring did not install or there is some kind of conflict.
Please look in /usr/share/apps/q4os_system/q4p_keyring/   and see if the file q4a-teamviewer.pub is there.
Also check in /etc/apt/sources.list.d/   and see if q4p-teamviewer-20220626055436-Rnq.list is there.
#3 2022-06-26 06:47
iaddo91
Yes, there are. What i have to do?
#4 2022-06-26 10:20
Initially I would suggest you run "sudo qrepoadd --gui" again and re-add the teamviewer repo.
Then run sudo apt update
Please copy and paste the terminal output from both these actions.
I'm wondering if there may be a translations issue - what is the system language set to?
#5 2022-06-26 12:43
iaddo91
terminal output:
Exist, not added: deb [signed-by=/usr/share/keyrings/q4a-teamviewer.gpg] http://linux.teamviewer.com/deb stable main
No repository has been added, as all exist yet
terminal output:
E: Impostati valori in conflitto per l'opzione Signed-By riguardo alla sorgente http://linux.teamviewer.com/deb/ stable: /usr/share/keyrings/q4a-teamviewer.gpg !=
Italian
#6 2022-06-26 15:54
I think we'll have to wait for the q4os team to look at this.
#7 2022-06-26 17:50
Teamviewer has added its own repository, so you only need to disable the redundant one. Run the command:
$ sudo qreporm teamviewer
$ sudo apt update
and post back
#8 2022-06-26 22:31
iaddo91
$ sudo apt update
and post back
thanks! it works!
