#1 2022-06-24 15:09
cwallen19803
Suspend resume desktop session locked
My desktop session locks from resume from suspend.  I'd rather it did not.  The machine already boots without a user password required.
I have unchecked Require password to stop on the screen saver config page.
I've seen and implemented suggestions from https hmm/www.q4os.org/forum/viewtopic.php?id=2157.  No success.
The lock screen actually appears before the system suspends.  Hibernate appears unobtainable in so far as the machine shuts down and immediately restarts, unrelated to this issue.  For now, I'd be happy if I could resume from suspend without typing in the user password.
kodi@kodi:/etc/systemd$ uname -r
5.10.0-15-amd64
kodi@kodi:/etc/systemd$  lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description:    Debian GNU/Linux 11 (bullseye)
Release:        11
Codename:       bullseye
#2 2022-06-25 06:23
Re: Suspend resume desktop session locked
In TDE you may find TDEPowersave>General Settings>Lock Screen is set to Lock before suspend/standby
#3 2022-06-25 18:52
cwallen19803
Thanks.  That option is unchecked.
At this point I'm wondering if there is a config file to edit.
I have this OS on a laptop and it does not have this behavior.  The lock screen options work as expected.
Possibly unrelated is the fact that the BIOS on this machine only supports S3 so hibernate just doesn't work and I'm relegated to Suspend.  Not the end of the world.  In any case, we're talking about behavior concerning Suspend and resume and the Lock Screen dialog that actually appears prior to the screen going blank as it suspends.
#4 2022-06-25 19:13
cwallen19803
I ended up going with
sudo mv kdesktop_lock kdesktop_lock.old
and a reboot.
Now there is no lockscreen.
Taking suggestions for a less heavy handed way of handling this :-)
#5 2022-06-26 05:47
How are you actually initiating the 'Suspend' please?
Also, please can you run inxi -F and paste the output here?
#6 2022-06-26 11:49
cwallen19803
I am initialing Suspend in what I assume is the standard manner, The Suspend Session button on the End Session dialog.  Nothing funky.  The results are the same if I use the Suspend option in the Kodi application. Systemctl suspend also works.
As indicated in my previous post, I rudely renamed the Lockdown dialog so the OS can never show it to me.
kodi@kodi:~$ inxi -f
CPU:
  Info: Dual Core model: Intel Core2 Duo E8400 bits: 64 type: MCP
  L2 cache: 6 MiB
  Speed: 1995 MHz min/max: 2000/3000 MHz Core speeds (MHz): 1: 1995 2: 1995
  Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
  cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht
  lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge
  pni pse pse36 pti rep_good sep smx sse sse2 sse4_1 ssse3 syscall tm tm2
  tpr_shadow tsc vme vmx vnmi vpid xsave xtpr
kodi@kodi:~$
