#1 2022-06-18 01:42
dfsrtrrgt
Find out my DDR4 memory RAM card model name using Q4OS ?
How to find out my DDR4 memory RAM card model name using a trinity desktop 32 bits Q4OS OS ?
#2 2022-06-18 05:28
Re: Find out my DDR4 memory RAM card model name using Q4OS ?
Open the case and have a look at the chip.
#3 2022-06-18 19:46
dfsrtrrgt
which chip ?
#4 2022-06-18 22:11
RAM chip, what else?
If you have no idea of what RAM looks like, you can find tons of images on the web.
#5 2022-06-20 00:38
dfsrtrrgt
in my RAM Memory Card says 1.2v what does it refers to ?
#6 2022-06-20 00:49
DDR4 uses 1.2 volts to operate at JEDEC standards.
#7 2022-06-20 05:59
Your RAM chip will have a maker's name and model number/part number as well as its capacity on it. You might need to take it out and look at both sides.
