#1 2022-06-13 01:27
Supaycha
Writing camera is not supported
When I want to add some file in my mobile phone appears this message. How to solve it? Thanks
#2 2022-06-13 06:36
Re: Writing camera is not supported
Assuming this is an Android phone install:-
gvfs-fuse gvfs-backends mtp-tools libmtp-runtime usbmuxd libusbmuxd-tools libimobiledevice4 libfm-tools gmtp
I have not had any success with gmtp but others have so it's worth a try.
After installation reboot and then connect your phone.
You'll need to tap a couple of settings on the phone to allow the USB connection and if offered choose media/pictures transfer.
If that doesn't work then just use File transfer. You should then be able to access the DCIM folder on the phone.
#3 2022-06-13 22:56
Supaycha
libimobiledevice4 isn't avalaible.
#4 2022-06-13 22:57
Supaycha
Doesn't work sad
#5 2022-06-14 05:58
libimobiledevice6 - typo.
Your reply contains nothing more useful than your original post so you are making it very hard to assist.
1. What make of phone
2. Connection USB?
3. What happens - if anything - on your phone screen when you attach it to your computer
4. What version of Q4OS
5. Does the USB port work with other devices such as mouse etc.
6. After you connect your phone, open Konsole and type 'sudo dmesg' - there should be a handful of lines relating to a USB connection at the bottom of the output. Please copy and paste here.
#6 2022-06-20 01:08
Supaycha
2. Connection USB?
1 Samsung Galaxy A02
2 Classical USB (IDK what kind of usb is it)
3 In my cellphone appears Allow "phone data access?"
4 Q4OS Gemini 64 Bits Trinity
5 Works good
6 [ 2206.242714] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2206.242769] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2206.242774] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2206.242829] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2206.242834] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2206.242888] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2206.242893] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2211.241705] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2211.241714] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2211.241770] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2211.241775] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2211.241828] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2211.241833] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2211.241888] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2211.241892] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2216.243022] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2216.243031] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2216.243087] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2216.243092] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2216.243146] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2216.243151] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2216.243205] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2216.243210] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2221.241513] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2221.241523] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2221.241578] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2221.241583] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2221.241639] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2221.241643] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2221.241698] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2221.241703] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2226.240677] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2226.240686] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2226.240742] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2226.240747] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2226.240802] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2226.240806] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2226.240861] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2226.240866] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2231.240060] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2231.240066] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2231.240100] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2231.240103] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2231.240136] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2231.240138] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2231.240171] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2231.240174] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2236.239225] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2236.239231] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2236.239265] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2236.239269] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2236.239302] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2236.239304] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2236.239337] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2236.239340] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2241.241690] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2241.241700] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2241.241761] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2241.241766] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2241.241824] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2241.241829] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2241.241887] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2241.241891] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2246.242287] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2246.242324] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2246.242382] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2246.242387] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2246.242441] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2246.242446] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2246.242501] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2246.242505] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2251.241629] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2251.241637] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2251.241692] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2251.241697] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2251.241751] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2251.241756] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2251.241811] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2251.241815] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2256.242954] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2256.242963] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2256.243020] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2256.243025] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2256.243080] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2256.243085] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2256.243139] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2256.243144] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2261.243060] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2261.243070] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2261.243116] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2261.243119] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2261.243165] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2261.243168] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2261.243210] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2261.243214] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2266.241248] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2266.241256] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2266.241312] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2266.241317] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2266.241371] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2266.241376] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2266.241431] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2266.241435] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2271.253118] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2271.253125] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2271.253165] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2271.253168] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2271.253206] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2271.253209] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2271.253247] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2271.253250] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2276.242871] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2276.242880] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2276.242936] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2276.242941] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2276.242995] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2276.243000] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2276.243055] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2276.243060] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2281.241036] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2281.241046] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2281.241106] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2281.241110] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2281.241167] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2281.241171] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2281.241228] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2281.241233] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2286.243246] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2286.243255] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2286.243313] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2286.243318] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2286.243374] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2286.243379] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2286.243434] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2286.243439] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2291.238691] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2291.238698] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2291.238734] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2291.238738] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2291.238775] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2291.238778] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2291.238814] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2291.238817] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2296.238981] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2296.238989] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2296.239029] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2296.239032] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2296.239070] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2296.239073] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2296.239111] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2296.239114] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2301.242517] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2301.242526] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2301.242582] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2301.242587] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2301.242642] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2301.242646] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2301.242700] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2301.242705] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2306.243346] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2306.243351] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2306.243389] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2306.243392] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2306.243429] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2306.243433] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2306.243469] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2306.243472] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2311.242519] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2311.242528] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2311.242585] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2311.242590] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2311.242646] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2311.242651] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2311.242705] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2311.242710] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2316.238200] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2316.238207] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2316.238246] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2316.238249] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2316.238286] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2316.238290] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2316.239289] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2316.239296] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2321.242748] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2321.242757] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2321.242814] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2321.242819] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2321.242985] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2321.242990] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2321.243049] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2321.243054] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2326.239017] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2326.239024] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2326.239061] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2326.239064] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2326.239101] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2326.239104] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2326.239141] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2326.239144] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2331.238814] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2331.238820] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2331.238854] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2331.238857] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2331.238890] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2331.238893] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2331.238925] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2331.238928] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2336.238097] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2336.238104] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2336.238141] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2336.238145] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2336.238180] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2336.238183] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2336.238220] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2336.238223] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2341.238888] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2341.238895] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2341.238932] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2341.238935] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2341.238972] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2341.238975] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2341.239011] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2341.239014] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2346.238287] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2346.238294] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2346.238363] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2346.238367] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2346.238404] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2346.238407] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2346.238445] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2346.238448] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2351.238672] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2351.238678] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2351.238715] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2351.238719] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2351.238755] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2351.238758] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2351.238795] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2351.238798] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2356.238669] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2356.238676] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2356.238713] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2356.238716] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2356.238753] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2356.238756] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2356.238794] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2356.238797] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2361.238593] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2361.238599] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2361.238636] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2361.238639] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2361.238676] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2361.238679] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2361.238717] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2361.238720] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2366.237815] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2366.237821] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2366.237859] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2366.237862] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2366.237900] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2366.237903] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2366.237940] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2366.237943] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2371.238251] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2371.238257] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2371.238291] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2371.238781] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2371.238832] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2371.238835] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2371.238871] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2371.238874] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2376.237898] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2376.237903] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2376.237937] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2376.237940] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2376.237972] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2376.237975] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2376.238008] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2376.238010] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2381.238375] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2381.238381] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2381.238419] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2381.238422] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2381.238460] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2381.238463] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2381.238499] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2381.238508] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2386.237862] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2386.237868] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2386.237906] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2386.237910] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2386.237947] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2386.237950] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2386.237986] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2386.237989] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2391.238342] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2391.238348] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2391.238385] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2391.238388] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2391.238424] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2391.238427] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2391.238463] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2391.238466] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2396.238060] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2396.238066] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2396.238105] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2396.238108] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2396.238145] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2396.238148] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2396.238184] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2396.238187] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2401.238081] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2401.238086] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2401.238123] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2401.238127] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2401.238166] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2401.238169] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2401.238205] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2401.238208] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2406.240038] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2406.240046] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2406.240086] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2406.240090] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2406.240128] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2406.240131] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2406.240169] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2406.240172] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2411.238518] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2411.238525] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2411.238565] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2411.238568] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2411.238608] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2411.238611] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2411.238649] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2411.238652] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2416.239578] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2416.239587] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2416.239643] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2416.239647] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2416.239702] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2416.239706] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2416.239761] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2416.239765] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2421.242102] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2421.242110] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2421.242166] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2421.242170] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2421.242225] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2421.242229] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2421.242283] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2421.242288] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2426.242799] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2426.242808] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2426.242865] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2426.242870] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2426.242925] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2426.242929] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2426.242984] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2426.242989] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2431.238448] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2431.238454] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2431.238488] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2431.238491] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2431.238524] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2431.238527] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2431.238560] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2431.238562] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2436.239707] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2436.239714] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2436.239751] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2436.239755] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2436.239791] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2436.239794] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2436.239831] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2436.239834] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2441.238527] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2441.238533] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2441.238572] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2441.238575] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2441.238612] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2441.238615] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2441.238653] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2441.238656] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2446.240046] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2446.240054] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2446.240112] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2446.240117] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2446.240172] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2446.240176] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2446.240230] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2446.240235] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2451.238462] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2451.238468] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2451.238505] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2451.238508] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2451.238544] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2451.238547] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2451.238584] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2451.238587] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2456.238160] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2456.238169] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2456.238204] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2456.238207] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2456.238240] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2456.238243] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2456.238276] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2456.238279] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2461.238285] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2461.238291] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2461.238679] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2461.238683] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2461.238723] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2461.238726] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2461.238765] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2461.238768] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2466.238138] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2466.238145] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2466.238182] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2466.238186] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2466.238223] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2466.238226] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2466.238263] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2466.238266] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2471.238624] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2471.238632] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2471.238688] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2471.238693] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2471.238748] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2471.238753] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2471.238808] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2471.238812] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2476.237910] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2476.237917] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2476.237954] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2476.237958] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2476.237995] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2476.237998] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2476.238034] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2476.238037] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2481.239581] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2481.239590] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2481.239647] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2481.239652] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2481.239707] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2481.239711] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2481.239768] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2481.239772] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2486.237992] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2486.237998] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2486.238036] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2486.238039] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2486.238075] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2486.238078] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2486.238114] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2486.238117] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2491.237875] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2491.237881] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2491.237918] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2491.237922] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2491.237958] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2491.237961] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2491.237998] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2491.238001] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2496.242596] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2496.242604] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2496.242660] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2496.242665] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2496.242720] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2496.242725] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2496.242780] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2496.242784] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2501.241978] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2501.241987] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2501.242042] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2501.242047] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2501.242101] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2501.242106] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2501.242161] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2501.242166] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2506.240675] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2506.240683] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2506.240738] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2506.240743] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2506.240798] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2506.240802] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2506.240858] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2506.240862] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2511.242578] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2511.242587] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2511.242642] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2511.242646] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2511.242701] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2511.242705] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2511.242760] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2511.242765] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2516.242590] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2516.242598] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2516.242655] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2516.242659] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2516.242714] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2516.242719] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2516.242773] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2516.242778] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2521.240102] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2521.240114] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2521.240160] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2521.240164] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2521.240206] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2521.240210] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2521.240254] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2521.240257] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2526.243803] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2526.243811] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2526.243851] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2526.243855] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2526.243893] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2526.243896] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2526.243935] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2526.243938] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2531.239134] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2531.239141] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2531.239179] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2531.239182] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2531.239219] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2531.239222] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2531.239258] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2531.239261] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2536.244151] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2536.244159] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2536.244198] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2536.244202] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2536.244240] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2536.244243] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2536.244281] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2536.244284] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2541.240357] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2541.240366] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2541.240423] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2541.240428] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2541.240484] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2541.240488] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2541.240545] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2541.240550] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2546.242222] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2546.242232] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2546.242326] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2546.243130] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2546.243215] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2546.243221] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2546.243282] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2546.243287] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2551.244179] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2551.244187] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2551.244229] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2551.244232] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2551.244273] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2551.244277] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2551.244316] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2551.244319] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2556.242060] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2556.242068] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2556.242124] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2556.242129] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2556.242184] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2556.242189] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2556.242245] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2556.242250] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2561.241780] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2561.241788] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2561.241845] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2561.241850] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2561.241904] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2561.241909] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2561.241963] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2561.241968] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2566.240835] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2566.240844] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2566.240899] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2566.240904] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2566.240959] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2566.240963] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2566.241018] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2566.241022] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2571.242559] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2571.242567] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2571.242625] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2571.242630] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2571.242685] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2571.242690] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2571.242745] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2571.242750] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2576.240926] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2576.240934] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2576.240989] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2576.240994] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2576.241048] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2576.241053] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2576.241108] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2576.241112] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2581.241649] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2581.241658] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2581.241714] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2581.241719] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2581.241773] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2581.241778] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2581.241832] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2581.241836] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2586.242489] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2586.242497] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2586.242553] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2586.242557] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2586.242612] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2586.242616] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2586.242675] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2586.242679] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2591.242865] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2591.242874] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2591.242929] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2591.242934] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2591.242989] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2591.242993] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2591.243050] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2591.243054] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2596.242798] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2596.242807] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2596.242862] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2596.242867] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2596.242921] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2596.242926] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2596.242980] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2596.242984] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2601.242567] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2601.242576] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2601.242632] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2601.242637] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2601.242691] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2601.242696] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2601.242751] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2601.242755] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2606.246373] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2606.246380] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2606.246420] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2606.246423] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2606.246463] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2606.246466] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2606.246504] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2606.246507] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2611.240500] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2611.240510] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2611.240552] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2611.240555] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2611.241092] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2611.241097] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2611.241154] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2611.241157] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2616.242202] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2616.242211] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2616.242268] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2616.242273] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2616.242372] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2616.242378] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2616.242603] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2616.242609] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2621.242058] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2621.242067] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2621.242124] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2621.242128] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2621.242183] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2621.242187] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2621.242243] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2621.242247] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2626.242549] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2626.242557] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2626.242614] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2626.242619] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2626.242674] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2626.242679] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2626.242733] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2626.242738] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2631.241883] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2631.241892] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2631.241948] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2631.241952] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2631.242008] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2631.242013] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2631.242068] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2631.242072] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2636.241296] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2636.241304] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2636.241362] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2636.241366] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2636.241423] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2636.241428] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2636.241484] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2636.241489] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2641.241879] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2641.241887] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2641.241943] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2641.241948] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2641.242002] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2641.242007] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2641.242062] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2641.242067] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2646.239766] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2646.239775] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2646.239832] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2646.239837] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2646.239892] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2646.239896] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2646.239951] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2646.239956] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2651.240912] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2651.240921] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2651.240976] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2651.240981] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2651.241035] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2651.241040] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2651.241095] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2651.241099] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2656.242771] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2656.242780] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2656.242836] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2656.242840] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2656.242896] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2656.242901] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2656.242955] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2656.242960] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2661.242427] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2661.242433] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2661.242470] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2661.242473] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2661.242510] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2661.242513] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2661.242550] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2661.242553] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2666.242610] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2666.242619] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2666.242675] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2666.242680] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2666.242736] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2666.242740] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2666.242795] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2666.242800] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2671.240963] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2671.240972] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2671.241027] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2671.241032] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2671.241087] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2671.241092] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2671.241146] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2671.241151] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2676.240992] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2676.241000] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2676.241056] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2676.241061] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2676.241116] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2676.241120] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2676.241175] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2676.241179] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2676.494386] usb 1-3: new high-speed USB device number 2 using ehci-pci
[ 2678.948052] usb 1-3: New USB device found, idVendor=04e8, idProduct=6860, bcdDevice= 2.23
[ 2678.948061] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2678.948067] usb 1-3: Product: SAMSUNG_Android
[ 2678.948072] usb 1-3: Manufacturer: SAMSUNG
[ 2678.948077] usb 1-3: SerialNumber: R58R705ZEVK
[ 2679.676094] usb 1-3: USB disconnect, device number 2
[ 2680.650382] usb 1-3: new high-speed USB device number 3 using ehci-pci
[ 2680.808054] usb 1-3: New USB device found, idVendor=04e8, idProduct=6860, bcdDevice= 2.23
[ 2680.808063] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2680.808069] usb 1-3: Product: SAMSUNG_Android
[ 2680.808073] usb 1-3: Manufacturer: SAMSUNG
[ 2680.808078] usb 1-3: SerialNumber: R58R705ZEVK
[ 2681.238849] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2681.238856] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2681.238893] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2681.238896] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2681.238934] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2681.238937] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2681.238973] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2681.238976] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2686.242706] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2686.242715] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2686.242771] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2686.242776] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2686.242832] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2686.242836] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2686.242891] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2686.242896] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2687.360007] usb 1-3: USB disconnect, device number 3
[ 2687.770358] usb 1-3: new high-speed USB device number 4 using ehci-pci
[ 2687.927673] usb 1-3: New USB device found, idVendor=04e8, idProduct=6860, bcdDevice= 2.23
[ 2687.927679] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2687.927683] usb 1-3: Product: SAMSUNG_Android
[ 2687.927686] usb 1-3: Manufacturer: SAMSUNG
[ 2687.927689] usb 1-3: SerialNumber: R58R705ZEVK
[ 2691.243086] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2691.243094] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2691.243149] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2691.243154] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2691.243209] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2691.243214] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2691.243270] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2691.243275] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2696.241819] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2696.241828] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2696.241885] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2696.241890] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2696.241945] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2696.241950] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2696.242006] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2696.242010] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2701.241048] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2701.241055] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2701.241103] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2701.241106] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2701.241146] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2701.241149] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2701.241189] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2701.241192] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2706.242604] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2706.242611] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2706.242651] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2706.242654] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2706.242692] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2706.242695] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2706.242734] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2706.242737] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2711.239528] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2711.239536] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2711.239592] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2711.239596] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2711.239652] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2711.239657] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2711.239712] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2711.239716] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2716.242425] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2716.242433] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2716.242492] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2716.242497] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2716.242554] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2716.242559] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2716.242618] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2716.242622] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2721.243702] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2721.243710] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2721.243766] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2721.243771] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2721.243826] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2721.243831] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2721.243886] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2721.243890] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2726.238678] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2726.238684] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2726.238722] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2726.238725] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2726.238762] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2726.238765] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2726.238808] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2726.238811] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2731.241047] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2731.241055] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2731.241111] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2731.241116] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2731.241171] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2731.241175] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2731.241230] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2731.241235] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2736.242546] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2736.242554] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2736.242610] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2736.242614] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2736.242668] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2736.242673] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2736.242728] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2736.242732] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2741.240197] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2741.240206] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2741.240263] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2741.240268] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2741.240324] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2741.240328] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2741.240384] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2741.240389] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2746.241099] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2746.241107] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2746.241163] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2746.241168] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2746.241222] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2746.241227] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2746.241285] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2746.241289] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2751.240942] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2751.240950] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2751.241006] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2751.241011] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2751.241065] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2751.241070] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2751.241125] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2751.241129] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2756.242164] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2756.242172] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2756.242227] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2756.242232] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2756.242286] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2756.243088] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2756.243162] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2756.243167] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2761.242770] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2761.242778] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2761.242835] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2761.242840] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2761.242895] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2761.242899] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2761.242955] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2761.242959] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2766.242281] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2766.242289] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2766.242749] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2766.242756] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2766.242815] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2766.242820] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2766.242876] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2766.242881] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2771.241234] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2771.241241] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2771.241297] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2771.241302] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2771.241357] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2771.241362] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2771.241419] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2771.241423] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2776.243085] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2776.243094] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2776.243150] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2776.243155] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2776.243209] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2776.243214] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2776.243270] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2776.243275] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2781.242970] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2781.242977] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2781.243015] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2781.243018] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2781.243054] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2781.243057] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2781.243095] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2781.243098] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2786.242450] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2786.242459] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2786.242514] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2786.242519] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2786.242575] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2786.242579] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2786.242635] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2786.242639] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2791.241498] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2791.241507] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2791.241563] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2791.241568] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2791.241623] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2791.241628] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2791.241683] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2791.241687] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2796.241149] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2796.241157] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2796.241212] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2796.241217] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2796.241273] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2796.241277] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2796.241332] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2796.241337] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2801.242754] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2801.242760] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2801.242797] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2801.242800] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2801.242837] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2801.242840] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2801.242878] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2801.242881] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2806.243143] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2806.243151] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2806.243208] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2806.243213] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2806.243269] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2806.243274] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2806.243329] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2806.243333] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2811.239451] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2811.239458] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2811.239500] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2811.239504] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2811.239545] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2811.239548] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2811.239587] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2811.239590] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2816.241746] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2816.241754] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2816.241810] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2816.241814] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2816.241869] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2816.241874] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2816.241929] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2816.241933] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2821.238209] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2821.238215] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2821.238253] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2821.238256] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2821.238297] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2821.238326] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2821.238370] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2821.238373] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2826.242906] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
[ 2826.242915] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
[ 2826.242974] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2826.242978] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2826.243035] thinkpad_acpi: acpi_evalf(BCTG, dd, ...) failed: AE_NOT_FOUND
[ 2826.243039] ACPI: \_SB_.PCI0.LPC_.EC__.HKEY: BCTG: evaluate failed
[ 2826.243100] thinkpad_acpi: acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
#7 2022-06-20 06:06
Re: Writing camera is not supported
OK - so, when you get the prompt on the phone "Allow data access" are you tapping it to allow?
I recall playing with a Samsung on Trinity years back and I'm pretty sure it comes up with a connection dialogue which you need to follow through.
#8 2022-06-21 00:54
Supaycha
Yes I do.
#9 2022-06-30 05:08
Supaycha
Any solution?
#10 2022-06-30 06:09
Well, daft though it may sound the only way I could get my old Samsung A3 (2015) to connect in TDE was by installing pcmanfm and using that I as able to access the phone. However it was not always easy or successful.
It is important that you provide some feedback to a question beyond Yes or No. I cannot see your phone or your PC so have no idea how you are doing this or what you are actually doing.
#11 2023-01-20 16:42
Supaycha
Well, after a long time I have used Q4OS again and this is what happens: my cell phone is a Galaxy A02, but it is taken as a camera. It uses a mini USB to connect and besides that I wouldn't know what else to add.
#12 2024-05-25 22:58
Supaycha
Hi there again! Now I'm using Q4OS Trinity Aquarium 64 bits and I still have the same error. My cellphone is an Android and still have reading like a camera. I can't trespass files to my cellphone on USB. Any solution?
#13 2024-05-26 09:12
Did you install and use Gmtp ? see https://q4os.org/dqa007.html#android . What is the error ?
#14 2024-05-26 23:02
Supaycha
Yes I did, and it still happens that my laptop takes my cell phone as if it were a camera. I think it's a Konqueror problem.
#15 2024-05-27 08:30
You need to run Gmtp application.
