#1 2022-04-08 12:49
ForestHawk
[SOLVED]cannot install from unsigned repo - MS Edge Dev Browser
Discover Updates Error Q4OS KDE 4.8
Cannot install from unsigned repo The following packages cannot be authenticated: microsoft-edge-dev
Any ideas?
Energy Flows where you Intention Goes.
#2 2022-04-09 12:02
Re: [SOLVED]cannot install from unsigned repo - MS Edge Dev Browser
Try to add Microsoft keyring:
$ sudo apt install curl
$ curl https://packages.microsoft.com/keys/microsoft.asc | gpg --dearmor > microsoft-key.gpg
$ sudo install -o root -g root -m 644 microsoft-key.gpg /etc/apt/trusted.gpg.d/
Reboot
#3 2022-04-09 15:27
ForestHawk
Thanks for the quick reply and instruction.
Installed Curl and ran Curl script Okay,
but on sudo install it seems to need more after the last line?
install: missing destination file operand After  'microsoft-key.gpg/etc/apt/trusted.gpg.d/'
#4 2022-04-09 15:42
We have updated the instructions, try to run them one by one once again.
#5 2022-04-09 18:18
ForestHawk
Q4OS Team Rocks!
That did the trick  Latest MS Edge Dev build on Q4OS 4.8!
Thank you
