#1 2022-02-24 10:09
judydudi
no sound on Fujitsu U7411
Hi
i have no sound on blank 4.7 trinity install on Fujitsu Lifebook 7411
tried
https://www.q4os.org/dqa011.html#install.3
but with no luck.
System:
  Host: fsojjiwmy Kernel: 5.10.0-11-amd64 x86_64 bits: 64
  Desktop: Trinity R14.0.11 Distro: Q4OS 4.7.1-n1
Machine:
  Type: Laptop System: FUJITSU CLIENT LIMITED product: LIFEBOOK U7411
  v: 10601736746 serial: <superuser required>
  Mobo: FUJITSU CLIENT LIMITED model: FJNB2E7 v: A4
  serial: <superuser required> UEFI: FUJITSU CLIENT LIMITED v: Version 2.28
  date: 12/22/2021
Battery:
  ID-1: CMB1 charge: 58.2 Wh condition: 64.6/64.6 Wh (100%)
CPU:
  Info: Quad Core model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
  L2 cache: 12 MiB
  Speed: 1215 MHz min/max: 400/4800 MHz Core speeds (MHz): 1: 1215 2: 1163
  3: 1339 4: 1485 5: 1148 6: 1163 7: 1587 8: 2006
Graphics:
  Device-1: Intel TigerLake GT2 [Iris Xe Graphics] driver: i915 v: kernel
  Device-2: Chicony FJ Camera type: USB driver: uvcvideo
  Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting
  unloaded: fbdev,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 20.3.5
Audio:
  Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: sof-audio-pci
  Sound Server: ALSA v: k5.10.0-11-amd64
Network:
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi
  IF: wlan0 state: up mac: 70:a6:cc:5a:14:91
  Device-2: Intel Ethernet I219-LM driver: e1000e
  IF: enp0s31f6 state: down mac: e4:46:b0:0a:b4:1f
Bluetooth:
  Device-1: Intel type: USB driver: btusb
  Report: ID: hci0 state: down address: 70:A6:CC:5A:14:95
Drives:
  Local Storage: total: 1.16 TiB used: 14.41 GiB (1.2%)
  ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG4AZNS1T02 KIOXIA
  ID-2: /dev/sda type: USB vendor: Corsair model: Corsair Voyager GTX
Partition:
  ID-1: / size: 95.56 GiB used: 11.82 GiB (12.4%) fs: ext4 dev: /dev/dm-0
  ID-2: /boot/efi size: 1020 MiB used: 32.8 MiB (3.2%) fs: vfat
  dev: /dev/nvme0n1p1
  ID-3: /home size: 375.74 GiB used: 2.56 GiB (0.7%) fs: ext4 dev: /dev/dm-1
Swap:
  ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
  dev: /dev/nvme0n1p5
Sensors:
  System Temperatures: cpu: 59.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 270 Uptime: 41m Memory: 30.97 GiB used: 2.2 GiB (7.1%)
  Shell: Bash inxi: 3.3.01
any help is appreciate.
#2 2022-02-24 12:39
stroudmw
Re: no sound on Fujitsu U7411
Have you checked that KMix has Current Mixer -> Master set to your audio hardware? Right-clicking on the speaker icon (on the system tray) should take you there. Alternatively, type kmix in the search bar (after clicking the Start button)
#3 2022-02-24 14:49
judydudi
thanks stoudmw
kmix seems ok.
audio server could not be started.
TDE Control says .- no soundcards -
Audio devices: NOT ENABLED IN CONFIG
tried to use newer kernel with
qinst-kernel-bpo
but got
This script is not enabled for the current distribution: bullseye
#4 2022-02-25 07:10
qinst-kernel-bpo
but got
You need to edit the script in /usr/bin/qinst-kernel-bpo
Third line down it checks for the release - at the moment it says
if [ "$A_QAPTDISTR" != "buster" ] ; then
You need to change that to
if [ "$A_QAPTDISTR" != "bullseye" ] ; then
This can be done by
sudo nano /usr/bin/qinst-kernel-bpo
edit the line
Ctrl-W to save
Ctrl-X to exit
Developers advised a while back - 21st November.
Not sure if you're using Pulseaudio at the moment. I recall you need to right click on the Kmix icon and select master channel - or something of that nature. Pulse should be installed by default but worth checking.
#5 2022-02-25 11:12
judydudi
thanks bin.
tried the new kernel with modified script with no luck.
by the way. the script is in /bin/qinst-kernel-bpo not /etc/...
still no sound.
#6 2022-02-25 11:47
The issue seems to be hardware dependent, we will try to get similar hardware, try to test and post back, if it passes.
#7 2022-02-25 12:35
judydudi
wow , many thanks for looking into it.
if it help:
a mx 21 live medium on that computer, audio works.
AlsaMixer says: Device sof-hda-dsp  chip Realtek ALC255
#8 2022-02-26 03:13
Intel Tiger Lake audio( Intel Realtek audio) requires at least the 5.14 kernel  or newer. Using a kernel older than 5.14 means not only your audio but some features of the Tiger Lake cpu wont work as intended.. MX21 uses the 5.14 kernel if Im not mistaken.
#9 2022-02-26 08:09
judydudi
thank you
MX21 live uses; 5.10.0-9-amd64
q4os4.7: 5.10.0-9-amd64
q4os4.7 after upgrade:5.10.0-11-amd64
q4os4.7 bp : 5.15.0-0.bpo.3-amd64
#10 2022-02-26 19:22
Most recent image for MX21 includes 5.14 kernel but you can also install from MX package installer in the kernel section.
Glad you got it working.
#11 2022-02-26 19:27
judydudi
thanks again. but still not working. there ist no difference between 5.10 and 5.15
#12 2022-03-02 10:06
judydudi
Ok, i solved it.
install the firmware-sof paket did the trick.
After restart i hear the q4os welcome sound.
#13 2022-03-02 11:01
Great, thanks for sharing that info. We will consider a direct support for this hardware in Q4OS, which could be automatic detection and offer firmware for installation on the first boot.
#14 2022-03-02 12:13
judydudi
that would be cool q4osteam.
to complete install information for the business notebook Fujitsu Lifebook 7411
(should work for Fujitsu 7311 and 7511 to)
for touchpad support i added with
sudo nano /etc/modules
i2c-hid
i2c-hid-acpi
i2c-hid is for the recent kernel (<5.12), i2c-hid-acpi works with backport kernel (>=5.12)
Thanks to this information : https://www.bw-pc.uni-freiburg.de/nutzung-von-linux
i did also changing Bios: >Advanced>Miscellaneous Configurations:
CPU Power Saving (AC) to "Normal"  and
CPU Power Saving (Battery) to "Normal"
That helped to optimise TDEpowersave standby mode (e.g. closing and opening notebook)
