#1 2022-02-19 18:23
SuperVictor64
How do I install the latest version of Wine 7.2 on Q4OS Trinity 32bit?
Is there a way to install the latest version of wine 7.2 on Q4OS Trinity 32 bit version?
#2 2022-02-20 06:58
Re: How do I install the latest version of Wine 7.2 on Q4OS Trinity 32bit?
https://wiki.winehq.org/Debian
Follow instructions for the base version of Debian behind your Q4OS installation
Stick with Stable 7.0 (winehq-stable) unless you are prepared for a few bumps along the way.
#3 2022-02-21 06:12
SuperVictor64
Can't I have the pastebin instructions of how to install wine on q4os trinity instead?
#4 2022-02-21 07:04
What do you mean?
#5 2022-02-21 17:03
SuperVictor64
What do you mean?
I mean can I have the Pastebin link for the instructions of how to install Wine 7.2 on Q4OS Trinity so I can copy and paste the commands on terminal?
#6 2022-02-22 06:41
As previously stated https://wiki.winehq.org/Debian
There you'll find the command to import the repo key - you do get a message saying apt-key is deprecated but it works fine
You copy and paste the relevant section from the sources info into either /etc/apt/sources.list or you create a new file wine.list in /etc/apt/sources.list.d
Either is correct but the latter is preferred.
You then follow the instructions to install the version you require - in your case you are looking at the development version.
I feel it only fair to mention that the wine vms created by 7.2 are huge. Just checked and with no software installed they come out at 1.2gb
