#1 2022-01-16 15:13
magenta-cuda
Bug: TDEPowersave Information Dialog: Battery State: -1%
The TDEPowersave Information Dialog often shows the Battery State as -1%. This is not a major problem as reloading the dialog corrects this.
#2 2022-01-16 17:10
Re: Bug: TDEPowersave Information Dialog: Battery State: -1%
We are not able to reproduce the issue, so that looks to be hardware dependent. Please provide a short hardware specification:
$ inxi -F
Anyone else noticed this issue ?
#3 2022-01-17 02:01
magenta-cuda
System:    Host: q4os-desktop Kernel: 5.10.0-10-686-pae i686 bits: 32 Desktop: Trinity R14.0.11 Distro: Q4OS 4.7.1-n1
Machine:   Type: Laptop System: Dell product: Inspiron 3180 v: 1.2.0 serial: DJQZ4L2
           Mobo: Dell model: 0918N8 v: A00 serial: .DJQZ4L2.CNWSC0081T00HJ. UEFI [Legacy]: Dell v: 1.2.0 date: 02/09/2018
Battery:   ID-1: BAT0 charge: 24.7 Wh condition: 24.7/32.0 Wh (77%)
CPU:       Info: Dual Core model: AMD A6-9220e RADEON R4 5 COMPUTE CORES 2C+3G bits: 64 type: MCP L2 cache: 1024 KiB
           Speed: 1191 MHz min/max: 1200/1600 MHz Core speeds (MHz): 1: 1191 2: 1190
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Stoney [Radeon R2/R3/R4/R5 Graphics] driver: amdgpu v: kernel
           Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
           Display: server: X.Org 1.20.11 driver: loaded: amdgpu,ati unloaded: fbdev,modesetting,vesa
           resolution: 1366x768~60Hz
           OpenGL: renderer: AMD STONEY (DRM 3.40.0 5.10.0-10-686-pae LLVM 11.0.1) v: 4.5 Mesa 20.3.5
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel
           Device-2: Advanced Micro Devices [AMD] Family 15h Audio driver: snd_hda_intel
           Sound Server: ALSA v: k5.10.0-10-686-pae
Network:   Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter driver: ath9k
           IF: wlp1s0 state: up mac: 5c:ea:1d:0a:5d:49
           Device-2: Qualcomm Atheros type: USB driver: btusb
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb
           Message: Required tool hciconfig not installed. Check --recommends
Drives:    Local Storage: total: 524.7 GiB used: 4.65 GiB (0.9%)
           ID-1: /dev/mmcblk0 type: USB model: 00000 size: 29.81 GiB
           ID-2: /dev/sda vendor: Dell model: WR202KD032G E70290F5 size: 29.12 GiB
           ID-3: /dev/sdb type: USB vendor: Seagate model: ST3500418AS size: 465.76 GiB
Partition: ID-1: / size: 9.86 GiB used: 4.65 GiB (47.2%) fs: ext2 dev: /dev/sdb20
Swap:      ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) dev: /dev/sdb6
Sensors:   System Temperatures: cpu: 41.0 C mobo: 41.0 C sodimm: SODIMM C gpu: amdgpu temp: 41.0 C
           Fan Speeds (RPM): N/A
Info:      Processes: 164 Uptime: 20m Memory: 3.76 GiB used: 1 GiB (26.6%) Shell: Bash inxi: 3.3.01
