#1 2021-11-14 04:37
theMezz
Auto Login WiFI on Bootup
Just did a default q4-s install
How do I made wifi connect auto on boot up
thx
#2 2021-11-14 06:58
Re: Auto Login WiFI on Bootup
When you go through the wifi connection settings process there is an auto connect checkbox.
#3 2021-11-14 23:41
theMezz
Not that I see
#4 2021-11-15 07:17
Which version of Q4 are you using and which desktop, TDE or Plasma?
#5 2021-11-17 17:30
abdulq4os
I have the same problem. I cannot figure out how to make wifi connect automatically on boot up. It's a bit frustrating.
#6 2021-11-18 06:17
Clint Burtwood
The auto connect checkbox only appears if you click next next next and so on, do not click on the first "apply and connect" thing that pops up, just click next until you see the checkbox. This is a design flaw.
#7 2021-11-25 19:12
abdulq4os
Thank you Clint Burtwood for your tip. It worked fine.
