#1 2021-10-23 15:36
Emiliano
Application menu problem
Hi everyone, I just installed Q4OS Gemini KDE basic version and started installing the software I need (firefox, chrome, libreoffice), but I don't see them in the applications menu.
If I launch them from the terminal they work, you can help me.
Thanks.
#2 2021-10-23 16:43
Re: Application menu problem
Firefox and Chrome should be in the "Applications" > "Internet", Libreoffice under "Office" section, aren't they there ?
Could you list them typing in the search box ?
#3 2021-10-23 19:23
Emiliano
After installing Discover all the apps appeared in their menu. ?
I don't understand why since I had installed them all from the terminal with apt
Thanks
