Hello everyone,
my name is Susanne and I have been working with Q4os since today. When booting the system, all the commands appear up to the login
The screen appears. Is it possible to remove this procedure or make it fancy, for example in MX Linux in the boot options with a topic? Maybe there is also the possibility to install an MX Boot Manager?
Please excuse my bad English.
Many thanks for your help
Susanne
The technical Datas of my computer are as follows:
susanne@susanne-pc:~$ inxi -Fxz
System:
Host: susanne-pc Kernel: 4.19.0-17-amd64 x86_64 bits: 64 compiler: gcc v: 8.3.0
Desktop: KDE Plasma 5.14.5 Distro: Q4OS 3.15.2-n1
base: Debian GNU/Linux 10 (buster)
Machine:
Type: Laptop System: Acer product: Aspire 4820TG v: V1.25 serial: <filter>
Mobo: Acer model: JM41_CP serial: <filter> BIOS: INSYDE v: 1.25 date: 03/16/2011
Battery:
ID-1: BAT1 charge: 47.1 Wh condition: 47.1/64.8 Wh (73%) model: PANASONIC AS10B5E
status: Full
CPU:
Topology: Dual Core model: Intel Core i5 M 460 bits: 64 type: MT MCP arch: Nehalem
rev: 5 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20217
Speed: 1463 MHz min/max: 1199/2534 MHz Core speeds (MHz): 1: 1463 2: 1463 3: 1463
4: 1463
Graphics:
Device-1: Intel Core Processor Integrated Graphics vendor: Acer Incorporated ALI
driver: i915 v: kernel bus ID: 00:02.0
Device-2: AMD Madison [Mobility Radeon HD 5650/5750 / 6530M/6550M]
vendor: Acer Incorporated ALI driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.4 driver: ati,modesetting,radeon
unloaded: fbdev,vesa resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel Ironlake Mobile v: 2.1 Mesa 18.3.6
direct render: Yes
Audio:
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Device-2: AMD Redwood HDMI Audio [Radeon HD 5000 Series]
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k4.19.0-17-amd64
Network:
Device-1: Qualcomm Atheros AR8151 v1.0 Gigabit Ethernet
vendor: Acer Incorporated ALI driver: atl1c v: 1.0.1.1-NAPI port: 2000
bus ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Broadcom Limited BCM43225 802.11b/g/n
vendor: Foxconn T77H103.00 Wireless Half-size Mini PCIe Card
driver: bcma-pci-bridge v: N/A port: 2000 bus ID: 03:00.0
IF-ID-1: wlp3s0b1 state: up mac: <filter>
Drives:
Local Storage: total: 931.51 GiB used: 6.57 GiB (0.7%)
ID-1: /dev/sda vendor: Western Digital model: WD10JPVX-22JC3T0 size: 931.51 GiB
temp: 35 C
Partition:
ID-1: / size: 908.23 GiB used: 6.57 GiB (0.7%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 7.78 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors:
System Temperatures: cpu: 38.0 C mobo: N/A gpu: radeon temp: 41 C
Fan Speeds (RPM): N/A
Info:
Processes: 179 Uptime: 29m Memory: 3.54 GiB used: 1.11 GiB (31.3%) Init: systemd
runlevel: 5 Compilers: gcc: 8.3.0 Shell: bash v: 5.0.3 inxi: 3.0.32
I found the solution here in the forum. I had to download the MX Tool package.
You could install grub-customizer too
sudo apt install grub-customizerOffline
Hello, thanks for the information. I reinstalled Q4os because the MX Tool is not always stable in some apps.
Could you please tell me which settings I have to make in Grub customizing, step by step so that I have a nice boot screen? I only work with KDE Plasma and it should boot a little faster if possible.
Q4OS' MX-Tools pkg installer is still in an experimental phase, it would be helpful if you could start a thread describing your experience while using it. About customizing grub, what is it exactly you'd like to do? Grub-customizer is an easy-to-use tool, it will allow you to set the background, font's size and color, amongst other things. This is a nice tutorial on theming grub http://wiki.rosalab.ru/en/index.php/Gru … e_tutorial give a read, then you can ask whatever questions you may have in your reply, and we'll try to answer those to the best of our abilities.
Thank you :-)
