#1 2021-08-23 10:58
I can not export existing profile for further modification.
Q4OS Gemini 4.5 x64 TDE r2.
When I try to export Full Featured desktop profile, the *.qdprrc file is not being saved. I have tried to save on different folders, same result.
Steps shown in screenshots:
1. https://drive.google.com/file/d/1gtpnRX … sp=sharing - Choose to export profile
2. https://drive.google.com/file/d/1gsa6Rg … sp=sharing - Choose destination folder
3. https://drive.google.com/file/d/1grgqzP … sp=sharing - Program shows, that profile has been exported and saved to file.
4. https://drive.google.com/file/d/1gmUTF3 … sp=sharing - The file does not exist in selected folder.
P.s. My photos are too big to be uploaded as attachments.
#2 2021-08-23 11:43
Re: I can not export existing profile for further modification.
We can confirm issues on saving custom Profiles. If you omit "_" character, the profile should save fine, alternatively try to save it directly to the $HOME/ folder. We are going to investigate and fix the bug, thanks for reporting.
#3 2021-08-23 16:31
I have omited "_" character, and tried to save *.qdprrc file to /home/adminq/Документы, and the file did not saved.
Then I tried to save file to /home/adminq, and the file saved successfully.
Then I created folder /home/adminq/Documents, and tried to save file there. File saved successfully.
Maybe Desktop profiler does not working properly, if the folder name where file should be saved contains non-latin characters?
