#1 2021-08-10 00:57
theMezz
quad pane file explorer
been trying to find a file explorer app for q4os without success
something like this  https://www.softwareok.com/?seite=Freeware/Q-Dir
thx
#2 2021-08-10 02:43
Re: quad pane file explorer
You can install 4pane, it's essentially an attempt to recreate q-dir in linux.
#3 2021-08-10 02:59
theMezz
thanks - i was hoping for something else.
4pane doesnt make it easy to have a differenr physical drive in each pane
appreciate your time
#4 2021-08-10 05:21
DavidB
You can do something like this in Konqueror....
#5 2021-08-10 05:40
The only other quad panel manager I'm even AWARE of for linux is Polo, which never had a full release, and the last beta is 3 years old.  The last beta that was released DOES still work on my KDE Neon install, however, if you wanted to risk trying it (I have absolutely no idea if it shows the hardware the way you want or not, I installed started and uninstalled just to see if it worked).
