#1 2021-05-25 16:23
sub13
Icon size toolbar
Hello
is it possible to change icon size in toolbar particulary for abiword
thank you
Asus Eee PC 1000H Atom N270 à 1.6 GHz ram 2go avec Q4os 3.16.1 centaurus
#2 2021-05-25 20:21
Re: Icon size toolbar
sub13 wrote:
Hello
thank you
KDE or TDE? If KDE, open system settings and click on appearance > icons there should be an option to configure the size, if there's not, click on advanced and look for the option to do what you want there. No idea how to in TDE, sorry.
#3 2021-05-27 10:22
sub13
Hello
I think i'm KDE Trinity,
but I don't find icon size
you can see capture sreen
thank you
#4 2021-05-28 05:40
First of all you need to open Konsole and run
sudo kcmodules --unlock
That will allow you to access all the config tools.
Then go to Control Centre>Appearance and Themes>Icons>Advanced
There you can select the icon size for the toolbar.
However that is purely for TDE/Trinity applications. So, it will affect Konqueror or Kwrite or other TDE specific programs
Abiword is a GTK program and so will not be affected by these changes.
https://wiki.archlinux.org/title/GTK gives useful insight into configuration for GTK2 and GTK3. However it is a bit trickier with TDE as it uses a different config file naming system. Coupled with the shift to GTK3 in Bullseye/Gemini it is only going to get harder working with configs.
#5 2021-05-28 06:42
sub13
Thank you, have a good day
