#1 2021-05-22 08:56
sub13
Num Lock & Scr Lock
Bonjour
Serait-il possible d'avoir un indicateur sur la barre des tâches pour savoir si mon claver est verrouillé en majuscule ou si les nombres sont verrouillés.
merci
Hello
Would it be possible to have an indicator on the taskbar to know if my keyboard is locked in upper case or if the numbers are locked.
thank you
Asus Eee PC 1000H Atom N270 à 1.6 GHz ram 2go avec Q4os 3.16.1 centaurus
#2 2021-05-22 09:19
Re: Num Lock & Scr Lock
If you use Trinity desktop, keyboard status panel applet could be useful, package "kbstate-trinity".
#3 2021-05-22 09:55
sub13
Hello
thank i install "kbstate-trinity". with synaptic but how can I find and use the keyboard status panel applet
thank you
#4 2021-05-22 10:05
It's a panel applet, so you need to unlock the panel and add the applet in.
#5 2021-05-22 10:09
sub13
Ok but I am french and New user on Q4os I Can you explain how to do.
Thank you
#6 2021-05-22 10:15
Right mouse click on the panel > Unlock panels > Right mouse click on the panel again > Add applet to panel > Select the desired applet > Click add to panel button > position the applet as you like > optionally Lock panel back
#7 2021-05-22 10:26
sub13
It is ok thank you
