#1 2021-05-20 10:16
quelgeek
LXTerminal 0.3.2 strange resizing in Trinity
When I change the font size or open a new tab in LXTerminal 0.3.2 the window spontaneously resizes to unusable dimensions. When I change the font size the window shrinks horizontally so that it is just wide enough to display the menu bar. When I add a tab it shrinks vertically to show just a couple of lines in the window. It allows me to drag the window boundaries out but when I release the mouse button it immediately snaps back to the size it was.
The exact same version on a Raspberry Pi is perfectly well-behaved.
What am I missing?
Roy
#2 2021-05-20 10:31
quelgeek
Re: LXTerminal 0.3.2 strange resizing in Trinity
To clarify, by Raspberry Pi I mean Raspbian 10 (buster)
#3 2021-05-20 12:10
Not able to reproduce this in TDE.
Please could you run inxi -F then copy and paste output in between
#4 2021-05-20 12:31
quelgeek
System:    Host: q4os-desktop Kernel: 4.19.0-16-amd64 x86_64 bits: 64 Desktop: Trinity R14.0.6
           Distro: Q4OS 3.14.2-n1
Machine:   Type: Vmware System: VMware product: VMware Virtual Platform v: N/A serial: <root required>
           Mobo: Intel model: 440BX Desktop Reference Platform serial: <root required> BIOS: Phoenix v: 6.00
           date: 07/02/2015
CPU:       Topology: 2x Single Core model: AMD FX-4350 bits: 64 type: SMP L2 cache: 4096 KiB
           Speed: 4200 MHz min/max: N/A Core speeds (MHz): 1: 4200 2: 4200
Graphics:  Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.15.0.0
           Display: x11 server: X.Org 1.20.4 driver: vmware unloaded: fbdev,modesetting,vesa
           resolution: 1920x1080~60Hz
           OpenGL: renderer: llvmpipe (LLVM 7.0 128 bits) v: 3.3 Mesa 18.3.6
Audio:     Device-1: Ensoniq ES1371/ES1373 / Creative Labs CT2518 driver: snd_ens1371
           Sound Server: ALSA v: k4.19.0-16-amd64
Network:   Device-1: Intel 82371AB/EB/MB PIIX4 ACPI type: network bridge driver: N/A
           Device-2: Intel 82545EM Gigabit Ethernet driver: e1000
           IF: ens33 state: up speed: 1000 Mbps duplex: full mac: 00:0c:29:b3:d1:69
Drives:    Local Storage: total: 100.00 GiB used: 14.74 GiB (14.7%)
           ID-1: /dev/sda vendor: VMware model: Virtual S size: 100.00 GiB
Partition: ID-1: / size: 89.80 GiB used: 14.62 GiB (16.3%) fs: ext4 dev: /dev/dm-0
           ID-2: /boot size: 235.3 MiB used: 91.3 MiB (38.8%) fs: ext2 dev: /dev/sda1
           ID-3: swap-1 size: 8.00 GiB used: 34.5 MiB (0.4%) fs: swap dev: /dev/dm-1
Sensors:   Message: No sensors data was found. Is sensors configured?
Info:      Processes: 194 Uptime: 2d 21m Memory: 7.77 GiB used: 1.07 GiB (13.8%) Shell: bash inxi: 3.0.32
#5 2021-05-20 13:55
VMWare - adds a bit of complication smile
Suggest you burn to USB, boot off USB and then install lxterminal via command line.
See what happens.
#6 2021-05-20 20:51
quelgeek
No need to mess about with USB sticks. I have the exact same software installed on bare metal. The problem reproduces exactly as on the VM.
FYI:
System:    Host: loathing Kernel: 4.19.0-13-amd64 x86_64 bits: 64 Desktop: Trinity R14.0.6
Machine:   Type: Desktop Mobo: GIGABYTE model: MZBAYAB-00 v: 1.x serial: <root required>
           UEFI [Legacy]: American Megatrends v: F9 date: 03/02/2018
CPU:       Topology: Quad Core model: Intel Celeron U1900 bits: 64 type: MCP L2 cache: 1024 KiB
           Speed: 1316 MHz min/max: 1280/2320 MHz Core speeds (MHz): 1: 1316 2: 1311 3: 1287
           4: 1316
Graphics:  Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display driver: i915
           v: kernel
           Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
           resolution: 1920x1080~50Hz
Audio:     Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
           driver: snd_hda_intel
           Sound Server: ALSA v: k4.19.0-13-amd64
Network:   Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter driver: rtl8723be
           IF: wlp2s0 state: down mac: 80:c5:f2:48:46:01
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
           IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: b4:2e:99:5d:91:06
Drives:    Local Storage: total: 111.80 GiB used: 4.83 GiB (4.3%)
           ID-1: /dev/sda vendor: Western Digital model: WDS120G2G0A-00JH30 size: 111.80 GiB
Partition: ID-1: / size: 101.77 GiB used: 4.83 GiB (4.7%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 7.89 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 65.0 C mobo: N/A
           Fan Speeds (RPM): N/A
Info:      Processes: 174 Uptime: 146d 22h 54m Memory: 7.69 GiB used: 880.1 MiB (11.2%)
#7 2021-05-20 23:49
We can confirm and reproduce the issue. We will investigate that and post back.
#8 2021-05-21 00:27
The issue looks to be upstream Trinity bug, as it's reproducible on vanilla Trinity/Debian stable system too. It depends on the GTK3 applications theme configuration. You can easily workaround the bug changing the GTK theme in the "$HOME/.configtde/gtk-3.0/settings_trinity.ini", set the line "gtk-theme-name=Adwaita" . If you use for example "Breeze" theme, the terminal behaves exactly the way you have described. We consider this issue as upstream bug, so reporting for Trinity developers would be helpful.
#9 2021-05-21 09:43
quelgeek
Is that something I need to do?
#10 2021-05-21 10:27
No, however you can:
1. workaround the issue to suppress that on your system, see above
2. report a bug for upstream Trinity developers http://trinitydesktop.org/
