#1 2016-02-06 17:13
noviclan
Cant install apps
q4os@q4os:~$ sudo dpkg --configure -a
Setting up libndesk-dbus1.0-cil (0.6.0-6) ...
* Installing 1 assembly from libndesk-dbus1.0-cil into Mono
Warning: Degraded allocation.  Consider increasing nursery-size if the warning persists.
Stacktrace:
  at <unknown> <0xffffffff>
please help me
#2 2016-02-06 17:27
Re: Cant install apps
Related to 'Mono', this could be helpful http://stackoverflow.com/questions/1846 … g-persists
#3 2016-02-06 18:05
noviclan
after "sudo apt-get update"
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
cant install any apps
#4 2016-02-06 18:10
Ok, first try
$ sudo apt-get remove libndesk-dbus1.0-cil
and report here
#5 2016-02-06 18:12
noviclan
q4os@q4os:~$ sudo apt-get remove libndesk-dbus1.0-cil
i dont have synaptic installed
after gdeb-i could not finish instalation f-spot this happened
#6 2016-02-06 19:08
Reboot and try:
if failed try:
$ sudo dpkg --force-all -r libndesk-dbus1.0-cil
$ sudo apt-get autoremove
and report here
#7 2016-02-06 20:16
noviclan
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
q4os@q4os:~$  sudo dpkg --force-all -r libndesk-dbus1.0-cil
(Reading database ... 70289 files and directories currently installed.)
Removing libndesk-dbus1.0-cil (0.6.0-6) ...
Removing libndesk-dbus1.0-cil from Mono
Stacktrace:
q4os@q4os:~$ sudo apt-get autoremove
q4os@q4os:~$
#8 2016-02-06 20:23
noviclan
at System.Globalization.CultureInfo..ctor (int,bool) <0x00017>
  at System.Globalization.CultureInfo..ctor (int) <0x00017>
  at System.Globalization.CultureInfo.CreateSpecificCultureFromNeutral (string) <0x013f7>
  at System.Globalization.CultureInfo.CreateSpecificCulture (string) <0x000d3>
  at System.Globalization.CultureInfo.ConstructCurrentCulture () <0x0003f>
  at System.Threading.Thread.get_CurrentCulture () <0x00037>
  at System.NumberFormatter..ctor (System.Threading.Thread) <0x0004b>
  at System.NumberFormatter.GetInstance () <0x0005b>
  at System.NumberFormatter.NumberToString (string,int,System.IFormatProvider) <0x0000b>
  at int.ToString (string,System.IFormatProvider) <0x0001b>
  at string.FormatHelper (System.Text.StringBuilder,System.IFormatProvider,string,object[]) <0x0045c>
  at string.Format (System.IFormatProvider,string,object[]) <0x00017>
  at string.Format (string,object) <0x0004b>
  at System.Globalization.CultureInfo..ctor (int,bool,bool) <0x000ef>
  at string.Format (string,object[]) <0x00017>
  at System.IO.TextWriter.Write (string,object[]) <0x00013>
  at System.IO.TextWriter.WriteLine (string,object[]) <0x0001b>
  at System.IO.SynchronizedWriter.WriteLine (string,object[]) <0x00043>
  at System.Console.WriteLine (string,object[]) <0x00037>
  at Mono.Tools.Driver.WriteLine (string,object[]) <0x0001f>
  at Mono.Tools.Driver.Main (string[]) <0x0080f>
  at (wrapper runtime-invoke) <Module>.runtime_invoke_int_object (object,intptr,intptr,intptr) <0xffffffff>
Native stacktrace:
        /usr/bin/mono() [0x80fea21]
        /usr/bin/mono() [0x814a12a]
        /usr/bin/mono() [0x8069945]
        linux-gate.so.1(__kernel_rt_sigreturn+0) [0xb77dcd28]
        /usr/bin/mono() [0x82194a2]
        /usr/bin/mono() [0x8219868]
        /usr/bin/mono() [0x822b4f7]
        /usr/bin/mono() [0x822badc]
        /usr/bin/mono() [0x822be75]
        [0xb709a930]
        [0xb7091700]
        [0xb628a584]
        [0xb628eebc]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
        [0xb628e984]
        [0xb628e1ad]
        [0xb628dd30]
        [0xb6290b04]
        [0xb6288920]
        [0xb6290998]
        [0xb6290968]
        [0xb62904c8]
        [0xb628ef5c]
        [0xb628eda0]
        [0xb628ed20]
        [0xb628eccc]
        [0xb628eb54]
        [0xb628e9b4]
Debug info from gdb:
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Aborted
W: removing assembly: NDesk.DBus, Version=1.0.0.0, Culture=neutral, PublicKeyToken=f6716e4f9b2ed099 failed!
Čitam spiskove paketa... Done
Gradim stablo zavisnosti
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
15 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up libglib2.0-cil (2.12.10-5.1) ...
Stacktrace:
#9 2016-02-06 21:24
Try:
$ sudo dpkg --force-all --purge libndesk-dbus1.0-cil
$ sleep 10
$ sleep 10
$ sudo dpkg --no-triggers --force-all --purge libndesk-dbus1.0-cil
$ sleep 10
and report here
#10 2016-02-06 21:33
noviclan
dpkg: warning: ignoring request to remove libndesk-dbus1.0-cil which isn't installed
q4os@q4os:~$ sleep 10
E: Could not get lock /var/cache/apt/archives/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/cache/apt/archives/
q4os@q4os:~$ sudo dpkg --no-triggers --force-all --purge libndesk-dbus1.0-cil
#11 2016-02-06 23:27
$ sudo dash /usr/share/apps/q4os_system/bin/qapt_fix.sh
#12 2016-02-07 09:27
noviclan
[sudo] password for q4os:
Waiting for package system to be released ..
Seems ready, will be checked once more.
Now safe ready.
Done.
Checking package system ..
The following packages have been unpacked but not yet configured.
They must be configured using dpkg --configure or the configure
menu option in dselect for them to work:
libart2.0-cil        CLI binding for libart 2.3
libflickrnet2.2-cil  Flickr.Net API Library
libgconf2.0-cil      CLI binding for GConf 2.24
libglade2.0-cil      CLI binding for the Glade libraries 2.6
libgnome-keyring1.0-cil CLI library to access the GNOME Keyring daemon
libgnome-vfs2.0-cil  CLI binding for GnomeVFS 2.24
libgnome2.24-cil     CLI binding for GNOME 2.24
libgtk2.0-cil        CLI binding for the GTK+ toolkit 2.12
libmono-addins-gui0.2-cil GTK# frontend library for Mono.Addins
libmono-system-web-applicationservices4.0-cil Mono System.Web.ApplicationServi
libmono-system-web-services4.0-cil Mono System.Web.Services (for CLI 4.0)
libmono-system-web4.0-cil Mono System.Web library (for CLI 4.0)
libmono-web4.0-cil   Mono.Web library (for CLI 4.0)
The following packages are only half configured, probably due to problems
configuring them the first time.  The configuration should be retried using
dpkg --configure <package> or the configure menu option in dselect:
libglib2.0-cil       CLI binding for the GLib utility library 2.12
libmono-addins0.2-cil addin framework for extensible CLI applications/librarie
The following packages have been triggered, but the trigger processing
has not yet been done.  Trigger processing can be requested using
dselect or dpkg --configure --pending (or dpkg --triggers-only):
libc-bin             GNU C Library: Binaries
systemd              system and service manager
Package system inconsistent, recovering ...
Setting up libmono-addins0.2-cil (1.0+git20130406.adcd75b-3) ...
* Installing 18 assemblies from libmono-addins0.2-cil into Mono
Stacktrace:
dpkg: error: parsing file '/var/lib/dpkg/status' near line 9927:
empty field name
#13 2016-02-08 19:11
We can check your system configuration and try to help. If you want so, run in terminal:
$ reportq4
and attach generated debug file here to analyze or send it via e-mail to support@q4os.org
#14 2016-02-09 10:20
noviclan
Okk
I send mail
#15 2016-02-10 12:34
We have analyzed debug files sent and tried to exactly simulate your desktop configuration. It cannot be done, as we have discovered you installed an unknown package 'dukto', it's not in any Q4OS compatible repositories. Which way exactly did you install this package ?
Your APT package system seems to be seriously corrupted and looks like it cannot be recovered by standard Q4OS tools. We recommend you to follow 'Fixing broken package script' manual recovering procedure https://www.debian.org/doc/manuals/debi … age_script
#16 2016-02-11 00:12
noviclan
Dukto is OK  100 %
failed attempt to install f-spot
unfinished installation
Instructions for 32 bit systems:
$ sudo apt-get install gdebi
$ wget download.opensuse.org/repositories/home:/colomboem/xUbuntu_12.04/i386/dukto_6.0-1_i386.deb
$ sudo gdebi dukto_6.0-1_i386.deb
