#1 2021-03-22 01:16
Kezza38
Kodi Install
Hi
I am inexperienced with Linux, attempting to setup an HTPC with an old Pentium system.
Tried Ubuntu but to slow, found Q4OS and installed and works better on my system.
Installed Kodi but does not show under applications and no icon on desktop.
Am I missing something?
msi@q4os-desktop:~$ sudo apt-get install kodi
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
libcwiid1 python-bluez
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
kodi-bin kodi-data kodi-repository-kodi kodi-visualization-spectrum
kodi kodi-bin kodi-data kodi-repository-kodi kodi-visualization-spectrum
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/24.2 MB of archives.
After this operation, 53.9 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Selecting previously unselected package kodi-bin:amd64.
(Reading database ... 175786 files and directories currently installed.)
Preparing to unpack .../kodi-bin_2%3a17.6+dfsg1-4+b1_amd64.deb ...
Unpacking kodi-bin:amd64 (2:17.6+dfsg1-4+b1) ...
Selecting previously unselected package kodi-data.
Preparing to unpack .../kodi-data_2%3a17.6+dfsg1-4_all.deb ...
Unpacking kodi-data (2:17.6+dfsg1-4) ...
Selecting previously unselected package kodi.
Preparing to unpack .../kodi_2%3a17.6+dfsg1-4+b1_amd64.deb ...
Unpacking kodi (2:17.6+dfsg1-4+b1) ...
Selecting previously unselected package kodi-repository-kodi.
Preparing to unpack .../kodi-repository-kodi_2%3a17.6+dfsg1-4_all.deb ...
Unpacking kodi-repository-kodi (2:17.6+dfsg1-4) ...
Selecting previously unselected package kodi-visualization-spectrum:amd64.
Preparing to unpack .../kodi-visualization-spectrum_1.1.1-1_amd64.deb ...
Unpacking kodi-visualization-spectrum:amd64 (1.1.1-1) ...
Setting up kodi-visualization-spectrum:amd64 (1.1.1-1) ...
Setting up kodi-data (2:17.6+dfsg1-4) ...
Setting up kodi-repository-kodi (2:17.6+dfsg1-4) ...
Setting up kodi-bin:amd64 (2:17.6+dfsg1-4+b1) ...
Setting up kodi (2:17.6+dfsg1-4+b1) ...
Processing triggers for mime-support (3.62) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for libc-bin (2.28-10) ...
Processing triggers for man-db (2.8.5-2) ...Processing triggers for desktop-file-utils (0.23-4) ...
msi@q4os-desktop:~$
msi@q4os-desktop:~$ inxi -F
System:
  Host: q4os-desktop Kernel: 4.19.0-14-amd64 x86_64 bits: 64
  Desktop: Trinity R14.0.6 Distro: Q4OS 3.14.2-n1
Machine:
  Type: Desktop Mobo: MSI model: H61M-P23 (MS-7680) v: 3.0
  serial: <root required> BIOS: American Megatrends v: 17.0 date: 03/14/2011
CPU:
  Topology: Dual Core model: Intel Pentium G850 bits: 64 type: MCP
  L2 cache: 3072 KiB
  Speed: 1596 MHz min/max: 1600/2900 MHz Core speeds (MHz): 1: 1596 2: 1596
Graphics:
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  driver: i915 v: kernel
  Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
  resolution: 1600x900~60Hz
  OpenGL: renderer: Mesa DRI Intel Sandybridge Desktop v: 3.3 Mesa 18.3.6
Audio:
  Device-1: Intel 6 Series/C200 Series Family High Definition Audio
  driver: snd_hda_intel
  Sound Server: ALSA v: k4.19.0-14-amd64
Network:
  Device-1: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet driver: atl1c
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: 6c:62:6d:3f:ac:9d
Drives:
  Local Storage: total: 186.31 GiB used: 5.53 GiB (3.0%)
  ID-1: /dev/sda vendor: Seagate model: ST3200827AS size: 186.31 GiB
Partition:
  ID-1: / size: 181.45 GiB used: 5.53 GiB (3.0%) fs: ext4 dev: /dev/sda1
  ID-2: swap-1 size: 976.0 MiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
Sensors:
  System Temperatures: cpu: 29.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 140 Uptime: 9m Memory: 3.77 GiB used: 334.4 MiB (8.7%)
  Shell: bash inxi: 3.0.32
kodi is already the newest version (2:17.6+dfsg1-4+b1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
msi@q4os-desktop:~$
Appreciate any advice.
#2 2021-03-22 01:22
Re: Kodi Install
Open konsole and try to launch kodi
kodi
Paste output here in your reply.
#3 2021-03-22 02:26
Kezza38
Re: Kodi Install
Hi
After I posted I tried "Run Command" Kodi and it worked.
I then found Kodi icon in Applications/Programs/Accessories/Multimedia.
