#1 2021-03-19 11:32
mechanic
Bouncing Icons
What happened to the bouncing desktop icons that used to feature in KDE3 that we all loved? I've tried searching through the kcontrol menus and clicking on 'desktop effects' in the welcome screen but no success. Have I just overlooked a setting somewhere?
#2 2021-03-19 13:02
Re: Bouncing Icons
Are using KDE or TDE? I use KDE and they're there. Not sure about TDE.
#3 2021-03-20 06:32
Re: Bouncing Icons
Open Konsole
sudo kcmodules --unlock
Go to Control Centre>Look'nFeel>Icons>Advanced>Animate Icons
Then go to Launch Feedback and set to Bouncing Cursor 10 seconds.
Hopefully that will do the trick smile
#4 2021-03-20 23:21
mechanic
Re: Bouncing Icons
Thanks for the detailed reply. Worked like a charm!
