#1 2021-03-16 10:08
menas
Wi-Fi via Access Point
Hello
I am using my mobile phone as an access point for wi-fi. I can connect some advices, but not my laptop. I get always the message:
"Secrets were required to enable the connection, no secrets were detected." There is also no menu to enter the password for the network.
I have tried to change something in the connection settings, but without success. WPA is set.
Who has an idea what to do?
#2 2021-03-16 10:15
Re: Wi-Fi via Access Point
What system do you use on your laptop ?
#3 2021-03-16 10:33
menas
Q4OS, Centaurus, Trinity Desktop, TDE (Basic)
#4 2021-03-16 10:40
You need to edit wireless network connection. Right mouse click on the network manager icon in the system tray > Edit connections > Select your wireless connection > click to Edit connection button
#5 2021-03-16 10:40
menas
I dit that
#6 2021-03-16 10:43
If you click "Next" in the Edit connections dialog  window, you can see "Shared key" box. Enter the password here and confirm.
#7 2021-03-16 10:47
menas
I see, now it seems to work. Thank you!
