#1 2018-04-20 18:12
BrJPedro
Update Manager doesn't work - Error 1004
Update Manager & Desktop Profiler are not working because they say that there's a error in Apt database integrity.
But Synaptic & command-line apt/aptitute/apt-get works well. I don't know what can be causing this error.
Today I've got a notification that updates were avalaible, and when I tried to update via Update Manager it shows me that error. So I went to Synaptic and update was succesfull.
#2 2018-04-20 19:12
Re: Update Manager doesn't work - Error 1004
One thing that can cause this behaviour is if you have installed any packages that are meant to be for another architecture, for instance when I installed my printer drivers it required some i386 packages on my amd64 system, these were installed and everything worked until such time as updates were required.
The good news is if this is the problem you have you could add the "foreign architecture" to apt and after an apt update everything should be working again. In my case I had to do :-
sudo dpkg --add-architecture i386
which after updating apt cleared the problem.
Of course there could be some other issue but this is one that I have had before. smile
#3 2018-04-21 15:31
BrJPedro
I tried to add the i386 architeture, but it fails yet. This is the screen error:
#4 2018-04-21 15:42
We will try to help you to resolve the issue. Please run a few commands in terminal and post output back:
$ sudo apt update
$ sudo apt dist-upgrade
$ sudo apt-get check
$ echo $?
#5 2018-04-21 15:57
BrJPedro
$ sudo apt update
sudo: could not resolve machine q4os
Reached: 1 http://security.debian.org stretch / updates InRelease
Ign: 2 http://deb.debian.org/debian stretch InRelease
Ign: 3 http://dl.google.com/linux/chrome/deb stable InRelease
Err: 4 ftp://ftp.debian.org/debian jessie InRelease
  Could not start connection to ftp.debian.org:21 (2001: 67c: 2564: a119 :: 148: 12). - connect (101: The network is out of range) [IP: 2001: 67c: 2564: a119 :: 148: 12 21]
Err: 5 ftp://ftp.debian.org/debian stretch InRelease
Attained: 6 http://ftp.debian.org/debian stretch-backports InRelease
Ign: 7 http://deb.debian.org/debian stretch / updates InRelease
Achieved: 8 http://deb.debian.org/debian stretch-updates InRelease
Reached: 9 http://dl.google.com/linux/chrome/deb stable Release
Achieved: 10 http://deb.debian.org/debian stretch Release
Err: 11 http://deb.debian.org/debian stretch / updates Release
  404 Not Found [IP: 151.101.92.204 80]
Reached: 12 http://q4os.org/q4repo q4os-2-0-cn InRelease
Achieved: 13 http://q4os.org/qtderepo stretch InRelease
Reading package lists ... Ready
E: The repository 'http://deb.debian.org/debian stretch / updates Release' does not have a Release file.
N: Updating from such a repository can not be done securely, and is therefore disabled by default.
N: See apt-secure (8) manpage for repository creation and user configuration details.
Building dependency tree
Reading status information ... Ready
Calculating update ... Ready
The following packages have been installed automatically and are no longer required:
  libappindicator1 libdbusmenu-gtk4 libindicator7
Use 'sudo apt autoremove' to remove them.
The following packages will be updated:
  fonts-opensymbol google-chrome-stable
2 packages updated, 0 new packages installed, 0 to be removed and 0 not upgraded.
You need to download 52.5 MB of files.
After this operation, an additional 164 kB of disk space will be used.
Do you want to continue? [S / n] S
Get: 1 http://security.debian.org stretch / updates / main amd64 fonts-opensymbol all 2: 102.7 + LibO5.2.7-1 + deb9u4 [260 kB]
Get: 2 http://dl.google.com/linux/chrome/deb stable / main amd64 google-chrome-stable amd64 66.0.3359.117-1 [52.2 MB]
Downloaded 52.5 MB in 7min 21s (119 kB / s)
(Reading database ... 328714 files and directories currently installed.)
Preparing to unpack ... / google-chrome-stable_66.0.3359.117-1_amd64.deb ...
Unzipping google-chrome-stable (66.0.3359.117-1) about (65.0.3325.181-1) ...
Preparing to unpack ... / fonts-opensymbol_2% 3a102.7 + LibO5.2.7-1 + deb9u4_all.deb ...
Unzip fonts-opensymbol (2: 102.7 + LibO5.2.7-1 + deb9u4) over (2: 102.7 + LibO5.2.7-1 + deb9u3) ...
Processing 'triggers' for mime-support (3.60) ...
Processing 'triggers' for desktop-file-utils (0.23-1) ...
Processing 'triggers' for menu (2.1.47 + b1) ...
Processing 'triggers' for man-db (2.7.6.1-2) ...
Setting google-chrome-stable (66.0.3359.117-1) ...
Configuring fonts-opensymbol (2: 102.7 + LibO5.2.7-1 + deb9u4) ...
Processing 'triggers' for fontconfig (2.11.0-6.7 + b1) ...
joaopedro@q4os:~$ echo $
joaopedro@q4os:~$ echo $?
0
#6 2018-04-21 16:12
You are mixing repositories for a start (Jessie and Stretch) which will never be a good experience, and it also looks like you are using ftp protocol for two of the repos which I do not think is usual and could be the reason they are failing.
I would start by changing the lines in your sources that start "ftp://ftp.debian" to read "http://ftp.debian"
Next I would ask myself if I really need two different version repositories in there, and if not then simply comment out any "Jessie" ones. then perform an apt update and see if that fixes the issue.
#7 2018-04-21 16:40
BrJPedro
$ sudo apt update
Reached: 1 http://q4os.org/q4repo q4os-2-0-cn InRelease
Reached: 2 http://q4os.org/qtderepo stretch InRelease
Ign: 4 http://deb.debian.org/debian stretch InRelease
Ign: 5 http://deb.debian.org/debian stretch / updates InRelease
Achieved: 7 http://deb.debian.org/debian stretch-updates InRelease
Achieved: 8 http://dl.google.com/linux/chrome/deb stable Release
Achieved: 9 http://deb.debian.org/debian stretch Release
Err: 10 http://deb.debian.org/debian stretch / updates Release
#8 2018-04-21 16:55
Please show the command you are using in your posts so we might understand why you are getting the
messages every time.
Also I think it possible you have more than one issue but I'm sure that will become more apparent as we go along.
could you post the output of apt policy
#9 2018-04-21 17:03
BrJPedro
This sudo message always appeared to me.
See:
joaopedro@q4os:~$ sudo echo anything
sudo: não foi possível resolver máquina q4os
anything
joaopedro@q4os:~$
joaopedro@q4os:~$ apt policy
Arquivos de pacote:
 100 /var/lib/dpkg/status
     release a=now
 500 http://dl.google.com/linux/chrome/deb stable/main amd64 Packages
     release v=1.0,o=Google, Inc.,a=stable,n=stable,l=Google,c=main,b=amd64
     origin dl.google.com
 100 http://ftp.debian.org/debian stretch-backports/non-free i386 Packages
     release o=Debian Backports,a=stretch-backports,n=stretch-backports,l=Debian Backports,c=non-free,b=i386
     origin ftp.debian.org
 100 http://ftp.debian.org/debian stretch-backports/non-free amd64 Packages
     release o=Debian Backports,a=stretch-backports,n=stretch-backports,l=Debian Backports,c=non-free,b=amd64
 100 http://ftp.debian.org/debian stretch-backports/contrib i386 Packages
     release o=Debian Backports,a=stretch-backports,n=stretch-backports,l=Debian Backports,c=contrib,b=i386
 100 http://ftp.debian.org/debian stretch-backports/contrib amd64 Packages
     release o=Debian Backports,a=stretch-backports,n=stretch-backports,l=Debian Backports,c=contrib,b=amd64
 100 http://ftp.debian.org/debian stretch-backports/main i386 Packages
     release o=Debian Backports,a=stretch-backports,n=stretch-backports,l=Debian Backports,c=main,b=i386
 100 http://ftp.debian.org/debian stretch-backports/main amd64 Packages
     release o=Debian Backports,a=stretch-backports,n=stretch-backports,l=Debian Backports,c=main,b=amd64
 500 http://deb.debian.org/debian stretch-updates/main i386 Packages
     release o=Debian,a=stable-updates,n=stretch-updates,l=Debian,c=main,b=i386
     origin deb.debian.org
 500 http://deb.debian.org/debian stretch-updates/main amd64 Packages
     release o=Debian,a=stable-updates,n=stretch-updates,l=Debian,c=main,b=amd64
 500 http://deb.debian.org/debian stretch/non-free i386 Packages
     release v=9.4,o=Debian,a=stable,n=stretch,l=Debian,c=non-free,b=i386
 500 http://deb.debian.org/debian stretch/non-free amd64 Packages
     release v=9.4,o=Debian,a=stable,n=stretch,l=Debian,c=non-free,b=amd64
 500 http://deb.debian.org/debian stretch/contrib i386 Packages
     release v=9.4,o=Debian,a=stable,n=stretch,l=Debian,c=contrib,b=i386
 500 http://deb.debian.org/debian stretch/contrib amd64 Packages
     release v=9.4,o=Debian,a=stable,n=stretch,l=Debian,c=contrib,b=amd64
 500 http://deb.debian.org/debian stretch/main i386 Packages
     release v=9.4,o=Debian,a=stable,n=stretch,l=Debian,c=main,b=i386
 500 http://deb.debian.org/debian stretch/main amd64 Packages
     release v=9.4,o=Debian,a=stable,n=stretch,l=Debian,c=main,b=amd64
 500 http://q4os.org/qtderepo stretch/main i386 Packages
     release v=9.0,o=q4os.org,a=qtde-stretch-st,n=stretch,l=Q4OS TDE repository,c=main,b=i386
     origin q4os.org
 500 http://q4os.org/qtderepo stretch/main amd64 Packages
     release v=9.0,o=q4os.org,a=qtde-stretch-st,n=stretch,l=Q4OS TDE repository,c=main,b=amd64
     origin q4os.org
 501 http://q4os.org/q4repo q4os-2-0-cn/main i386 Packages
     release v=2.0,o=q4os.org,a=q4os-2-0-st,n=q4os-2-0-cn,l=q4os-2-0 repository,c=main,b=i386
     origin q4os.org
 501 http://q4os.org/q4repo q4os-2-0-cn/main amd64 Packages
     release v=2.0,o=q4os.org,a=q4os-2-0-st,n=q4os-2-0-cn,l=q4os-2-0 repository,c=main,b=amd64
     origin q4os.org
Pacotes alfinetados ("pinned"):
#10 2018-04-21 17:09
It appears, you have corrupted your sources.list file. Please post contents of the debian lists file:
$ cat /etc/apt/sources.list.d/20_debian.list
The correct '/etc/apt/sources.list.d/20_debian.list' file should look like this:
# Q4OS essential repository
# **** !!! NEVER touch this CRITICAL system file **** !!!
deb http://ftp.debian.org/debian/ stretch main contrib non-free
#deb-src http://ftp.debian.org/debian/ stretch main contrib non-free
deb http://security.debian.org/debian-security/ stretch/updates main contrib non-free
#deb-src http://security.debian.org/debian-security/ stretch/updates main contrib non-free
# stretch-updates, previously known as 'volatile'
deb http://ftp.debian.org/debian/ stretch-updates main contrib non-free
#deb-src http://ftp.debian.org/debian/ stretch-updates main contrib non-free
##deb http://ftp.debian.org/debian/ stretch-proposed-updates main contrib non-free
##deb-src http://ftp.debian.org/debian/ stretch-proposed-updates main contrib non-free
# mirror chooser service - experimental
##deb http://deb.debian.org/debian/ stretch main contrib non-free
##deb-src http://deb.debian.org/debian/ stretch main contrib non-free
#11 2018-04-21 17:13
BrJPedro
It appears, you have a corrupted sources.list file. Please post contents of your debian lists file:
Here it is:
deb-src http://deb.debian.org/debian/ stretch/updates main contrib non-free
deb http://deb.debian.org/debian/ stretch-updates main contrib non-free
I edited the file like you said, and now I will run $ sudo apt update to see if that fixes the problem.
#12 2018-04-21 18:42
BrJPedro
$ sudo apt update now works like a charm.
But Update Manager not. :'/
joaopedro@q4os:~$ sudo apt update
[sudo] senha para joaopedro:
Ign:1 http://dl.google.com/linux/chrome/deb stable InRelease
Atingido:2 http://dl.google.com/linux/chrome/deb stable Release
Ign:3 http://ftp.debian.org/debian stretch InRelease
Atingido:4 http://security.debian.org/debian-security stretch/updates InRelease
Atingido:5 http://ftp.debian.org/debian stretch-updates InRelease
Atingido:7 http://ftp.debian.org/debian stretch-backports InRelease
Atingido:8 http://ftp.debian.org/debian stretch Release
Atingido:9 http://q4os.org/q4repo q4os-2-0-cn InRelease
Atingido:11 http://q4os.org/qtderepo stretch InRelease
Lendo listas de pacotes... Pronto
Construindo árvore de dependências
Lendo informação de estado... Pronto
All packages are up to date.
joaopedro@q4os:~$
Update Manager:
#13 2018-04-21 18:53
Could you install inxi and post the output of
inxi -rS
and also post the output of
cat /etc/hosts
EDIT: and have you rebooted your machine at all? if not could you reboot and check updater again?
#14 2018-04-21 19:26
BrJPedro
$ inxi -rS
System:    Host: q4os Kernel: 4.9.0-6-amd64 x86_64 (64 bit)
           Desktop: KDE Plasma 3 Distro: Debian GNU/Linux 9 (stretch)
Repos:     Active apt sources in file: /etc/apt/sources.list.d/10_q4os.list
           deb http://q4os.org/q4repo q4os-2-0-cn main
           deb-src http://q4os.org/q4repo q4os-2-0-cn main
           Active apt sources in file: /etc/apt/sources.list.d/12_qtde.list
           deb http://q4os.org/qtderepo stretch main
           deb-src http://q4os.org/qtderepo stretch main
           Active apt sources in file: /etc/apt/sources.list.d/20_debian.list
           Active apt sources in file: /etc/apt/sources.list.d/30_debian_backports.list
           deb http://ftp.debian.org/debian/ stretch-backports main contrib non-free
           deb-src http://ftp.debian.org/debian/ stretch-backports main contrib non-free
           Active apt sources in file: /etc/apt/sources.list.d/google-chrome.list
           deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
joaopedro@q4os:~$
Hosts
joaopedro@q4os:~$ cat /etc/hosts
127.0.0.1       localhost
127.0.1.1       q4os-desktop
# The following lines are desirable for IPv6 capable hosts
::1     localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
#15 2018-04-21 19:37
I would change the second line in your /etc/hosts file so it reads
127.0.0.1       localhost
127.0.1.1       q4os
which should solve your error output for your machine name, it might also solve the updater issue too (fingers crossed).
#16 2018-04-21 19:55
BrJPedro
Everything is working fine now! <3
Thank you Dai_trying and q4osteam for the help!
#17 2018-04-21 20:05
You are welcome smile
EDIT:
One thing you might want to do is remove the i386 repository as it is likely you do not actually need it (unless you know it is needed) which can be done using the command
sudo dpkg --remove-architecture i386
#18 2021-03-03 14:54
kwhitefoot
I know his is two years old but the fix that I used isn't here so perhaps it might be useful to others.
The problem occurre after I changed the hostname from q4os to carrot.  Synaptic continued to work but the Software Centre kept saying that the apt db was corrupt and that it could not resolve the hostname (carrot).
and change it to say
    127.0.1.1 carrot
Then installing from the Software Centre worked.
#19 2021-03-07 13:46
@kwhitefoot
Which way did you change the hostname ?
