#1 2021-02-19 04:44
HemanthJabalpuri
Full Offline Windows Installer
Sir, thanks for the great Distro and Windows Installer.
Can you please give another exe for the user, that has distro embedded in exe. So that we can install it in offline environment like PhoenixOS Android does.
Thanks
#2 2021-02-19 08:18
Re: Full Offline Windows Installer
It's possible to use the current installer offline. You need to have the installer and image file "q4os-3.0-x64-loop.img.xz" downloaded, and subsequently  run in Windows command prompt:
q4os-winsetup.exe --dimagepath=c:\full_path_to_the_image\q4os-3.0-x64-loop.img.xz
For more info about possible installer options please read https://github.com/hakuna-m/wubiuefi/wi … arameters-
#3 2021-02-19 08:30
HemanthJabalpuri
For more info about possible installer options please read https://github.com/hakuna-m/wubiuefi/wi … parameters-
Oh, so all things explained at https://github.com/hakuna-m/wubiuefi/wiki/FAQ will also work with Q4OS too?
Like placing iso in the same folder or giving iso as parameter etc.,
Thanks
#4 2021-02-19 09:03
No, not all of the parameters will work, however most of them do. For example you can install Q4OS from disk image, but not from iso image.
#5 2021-02-19 10:44
HemanthJabalpuri
Oh, then we definitely need the iso option since there is no disk image for latest Q4OS. Or release the disk image of the latest one.
If there is no iso option, then how it will install latest one??
Thanks
#6 2021-02-19 12:08
... there is no disk image for latest Q4OS...
The disk image is available, the file "q4os-3.0-x64-loop.img.xz", you can download it from the SourceForge repository, see above.
#7 2021-02-19 14:51
HemanthJabalpuri
Sorry if I am annoying. Since I am a new Linux user.
I found img at https://sourceforge.net/projects/q4os/files/stable/
Why it is versioned as 3.0 instead of 3.14?
Also q4os-3.0-x64-loop.img.xz is Trinity or Plasma?
Why I am asking these questions instead of trying myself is that, I have less Internet and cannot download again and again.
Thanks
#8 2021-02-19 15:15
The "q4os-3.0" means the complete line, you get 3.13 version as you install it. Once you update the system from repositories, you get the most recent 3.14 version.
#9 2021-02-19 16:54
HemanthJabalpuri
Thanks for reply.
Please add iso support to windows installer, so that we can install normal releases like 3.14.
Also uninstalling is not removing GRUB.
#10 2021-02-22 19:12
Sorry about riding someone else's thread for this report, but I believe my post is on-topic.
(Before I start and for anyone interested, let me just state that, funnily enough with the quarantine and all, I haven't had much time to go on with my Q4OS experiments lately.)
I just did another quick run of 'q4os-winsetup.exe' from Windows (v10[.0.19041.388] this time) booted off a virtual disk, with the parameters in post #2.
It quickly failed -- log is at https://rentry.co/iab9m.
It looks like q4os-winsetup tried to run 'C:\Windows\sysnative\bcdedit.exe /enum' and gave up when it got back a negative.
I never changed anything related to 'bcedit.exe' so went looking for it: turns out it is still present in plenty locations (36, no less), with the most obvious being 'C:\Windows\System32\' (no 'sysnative' dir, though).
When I tried manually running 'bcdedit /enum' as admin just to see what would come out, I got another error:
The boot configuration data store could not be opened.
The requested system device cannot be found.
But this Windows has been working fairly well for a couple of months now, with no boot errors or any serious crashes.
For completeness, here's the output of Diskpart:
DISKPART> list volume
  Volume ###  Ltr  Label        Fs     Type        Size     Status     Info
  Volume 0     Z                       DVD-ROM         0 B  No Media
  Volume 1     D   SSD-ADATA    NTFS   Partition    100 GB  Healthy    System
  Volume 2         VTOYEFI      FAT    Partition     32 MB  Healthy
  Volume 3     E   HDD-DATA     NTFS   Partition    465 GB  Healthy
  Volume 4         System Rese  NTFS   Partition     50 MB  Healthy
  Volume 5     C                NTFS   Partition     63 GB  Healthy    Boot
Note that "Volume 5" is in fact a VHD file residing in "Volume 1" -- a Mint Linux liveCD ISO (v20 64-bit) residing at the same location also boots perfectly. "Volume 3" is on a physical HDD and that's where I intended to place Q4OS.
#11 2021-02-22 21:32
@Midas
Thanks for the report we will take a look to check for possible bcdedit caveats.
#12 2021-03-09 22:35
Quick note for a real feature request, this time:
I understand it's beneficial from a branding POV to have your own Windows installer but wouldn't it make the developing burden easier if you just made the Windows installer be the vanilla Wubiuefi -- and just make instructions available for Q4OS to be used with it? Assuming there are no deep rooted technical reasons preventing this...
Wubiuefi already provides some information on setting up non-Ubuntu distros (cf. https://github.com/hakuna-m/wubiuefi/wi … sversions), but I wouldn't know which way to go if I wanted to try it on my own.
