#1 2021-02-02 10:57
TDM Theme changing
Centaurus TDE
I have been trying - unsuccessfully - to use a different theme for TDM.
Once upon a time in the days of KDE 3 there was a theme change utility and I have installed tdmtheme-trinity.
However if you go to Administrator mode it just crashes when you hit Enable Themes.
Is it just not possible with the modern TDM?
#2 2021-02-02 12:22
Re: TDM Theme changing
What system do you use ?
#3 2021-02-02 12:52
Umm..sorry, not exactly sure what you need to know.
TDE Centaurus - 3.13.1 14.06 64bit Intel - currently testing this in a VM but that shouldn't make any difference.
#4 2021-02-02 13:07
Yes, that's what we needed, we are going to test it as well.
#5 2021-02-02 17:34
We are not able to reproduce the issue, changing TDM theme is working fine in Virtualbox as well as on a real hardware.
Testing procedure:
- Virtualbox 6, 2GB RAM
- Clean installation Q4OS 3 Centaurus TDE from the live media, q4os-3.13-x64-tde.r1.iso
- Install "tdmtheme-trinity" package
- Run the Control panel from the start menu > System administration > TDM theme manager > Administrator mode > Enable TDM themes > Select a "O2 enterprise" theme > Apply > Ok
- Reboot and check the TDM screen
What could be a different from your configuration ?
#6 2021-02-03 08:54
Probably it's because I'm a twit smile
What I was doing was just checking Enable Themes>Apply
I then expected to be able to access the list and pick a theme.
Following your method of Enable and the pick theme at the same time does of course work perfectly.
Sorry to have been a pain - lockdown is getting to the old brain cell!
#7 2021-02-03 11:18
No problem with that, any meaningful reporting is appreciated. Thanks for contributing in this forum.
